Massey 1734e vs delux vs Kioti CK3510se
   / Massey 1734e vs delux vs Kioti CK3510se #11
I went kioti. Honestly didn’t compare against MF primarily looked at Kubota L3301 and L3901) but looking at TractorData with kioti you get a little more width, quite a bit more engine displacement/likely = torque, and a ton more loader capacity. And no turbocharger for maintenance issues. Not enough to rule the MF out if it fits you or your budget better, but if all else is equal then it seems clear.
This is exactly where I started and ended with the Kioti. I also can't compare to massey but I was dead set on buying a Kubota,... but ended up preferring the Kioti in almost all areas. But if you are snow blowing a cab and mid PTO are paramount.
New/Unused Quick Attach Pallet Forks (A57454)
New/Unused Quick...
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59575)
2007 STERLING...
1998 CASE 580SL Backhoe (A59213)
1998 CASE 580SL...
2007 Yamaha Rhino 660 (A56436)
2007 Yamaha Rhino...
2020 CATERPILLAR 299D3 XE SKID STEER (A52709)
2020 CATERPILLAR...
