Massey 1734E DIY Rubber Floor
   / Massey 1734E DIY Rubber Floor #1
LukeDuke30
Indiana
2016 Massey 1734e
Since the E-series do not come with rubber floors I decided to make some myself. I bought a 4'x6'x3/4'' stall mat from Rural King.
It was really straight forward - I removed the existing floors to use as a template. I went through about 10 razor blades, but in the end it took about an hour to remove, cut, and make small adjustments for a good fit. I used some carriage bolts and nylock nuts through the existing floorboard holes. It turned out nice for $30.
   / Massey 1734E DIY Rubber Floor #2
Nice! I'm going to steal that idea:thumbsup:
   / Massey 1734E DIY Rubber Floor #4
Very nice work! A lot cheaper than having it sprayed with Line-X or Rhino Lining.
   / Massey 1734E DIY Rubber Floor #5
Nice, I may do this to my 'bota :)
   / Massey 1734E DIY Rubber Floor #6
Very nice...doubt you'll ever wear a hole/tear that mat!
Another benefit of this mat is the weight of it. As we all know, tractors of similar size could always use the extra weight. This 4x6 sheet I used weights almost 100 lbs.
I weighed the material I added to the tractor, and it was about 30 lbs. Not a ton, but it all adds up especially with filled tires.
   / Massey 1734E DIY Rubber Floor #8
Wow. Nice job on the fit!
Just curious. Was that $30 for the amount you used or $30 for the 4'x6' piece??
$30 for the 4'x6' piece. I would have bought a smaller size, but that was the only size they carried in 3/4''.
   / Massey 1734E DIY Rubber Floor #10
Thanks for the reply. I recently purchased two 4x6x3/4" mats for my home gym. ON SALE for $69 per mat.
Locally they are up to $100 each. :(
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
6x14 Double Axle Bumper Pull Trailer (A51572)
6x14 Double Axle...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2014 INTERNATIONAL MA025 (A52472)
2014 INTERNATIONAL...
2018 Vermeer Chipper (A51573)
2018 Vermeer...
