Massey 1734E DIY Rubber Floor
   / Massey 1734E DIY Rubber Floor #1
LukeDuke30
Indiana
2016 Massey 1734e
Since the E-series do not come with rubber floors I decided to make some myself. I bought a 4'x6'x3/4'' stall mat from Rural King.
It was really straight forward - I removed the existing floors to use as a template. I went through about 10 razor blades, but in the end it took about an hour to remove, cut, and make small adjustments for a good fit. I used some carriage bolts and nylock nuts through the existing floorboard holes. It turned out nice for $30.
   / Massey 1734E DIY Rubber Floor #2
Nice! I'm going to steal that idea:thumbsup:
   / Massey 1734E DIY Rubber Floor #4
Very nice work! A lot cheaper than having it sprayed with Line-X or Rhino Lining.
   / Massey 1734E DIY Rubber Floor #5
Nice, I may do this to my 'bota :)
   / Massey 1734E DIY Rubber Floor #6
Very nice...doubt you'll ever wear a hole/tear that mat!
Another benefit of this mat is the weight of it. As we all know, tractors of similar size could always use the extra weight. This 4x6 sheet I used weights almost 100 lbs.
I weighed the material I added to the tractor, and it was about 30 lbs. Not a ton, but it all adds up especially with filled tires.
   / Massey 1734E DIY Rubber Floor #8
Wow. Nice job on the fit!
Just curious. Was that $30 for the amount you used or $30 for the 4'x6' piece??
$30 for the 4'x6' piece. I would have bought a smaller size, but that was the only size they carried in 3/4''.
   / Massey 1734E DIY Rubber Floor #10
Thanks for the reply. I recently purchased two 4x6x3/4" mats for my home gym. ON SALE for $69 per mat.
Locally they are up to $100 each. :(
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A51694)
2017 Nitro Z 19ft...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
2019 KEESTRACK K6 SCALPING SCREENER (A51246)
2019 KEESTRACK K6...
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
2023 John Deere 408R Sprayer (A53342)
2023 John Deere...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
