massey 1552 will not move
/ massey 1552 will not move #1
BCL2
suffolk, va
massey ferguson1552
I have a massey ferguson 2008 with a power shuttle DQS transmission that will not move, PTO does not work. Any suggestions where to start. Engine runs fine
Just a little history, had to replace the cam shaft and associated gears so separated the tractor, broke the motor down, replaced damaged parts and put it back together. Motor started right up and runs great. However, all the dash indicators show the gears are shifting and PTO is engaged but nothing happens. I have changed all the fluid and filters, still nothing.
I am really scratching my head on this one. Anyone have any similar problems or suggestions?
/ massey 1552 will not move #2
Bcl
I am not familiar with your tractor but my first thought is to double check the hydraulic pump that feeds the shuttle shift and PTO is connected properly. Possibly a line or fitting is not connected properly after splitting the tractor.
If the PTO and shift are electric operated double check all of the wiring and if possible verify that you are getting a signal to the coils that control the PTO and shuttle shift.
Also might help to post this question in the Massey section of this forum
2022 Load Lifter 5000 (A64911)
2022 Load Lifter...
LINCOLN ARC WELDER (A67714)
LINCOLN ARC WELDER...
2006 PETERBILT 379 (INOPERABLE) (A67714)
2006 PETERBILT 379...
New Holland Workmaster 25 (A64911)
New Holland...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
John Deere 4039 TF001 Pumping Unit (A64911)
John Deere 4039...
