Massey 1440 rear ring and pinion.
   / Massey 1440 rear ring and pinion. #1
frankd1
Lucknow, Ontario
MF1440-4 ,MF/GC2610TLB
I have a 2004 Massey Ferguson 1440 compact tractor. 5 out of the 8 bolts broke holding the ring gear to the differential. Chewed some mark on the ring and pinion gear. Ring and Pinion are no longer available. Havent had any luck finding a used set. Anybody have one kicking around? Or know of one?
Thanks
Frank
   / Massey 1440 rear ring and pinion. #2
Thanks
Frank
Any luck? I have the same exact problem
No luck finding new or used ring and pinion for mine. The contact area was not really damaged. I removed the burs and polished with a stone, ordered new bolts and had a good contact patern with proper backlash.
It is working good. Is yours gear or hydro? Mine is gear and is a different ratio than hydro. I did find a burnt hydro at a wrecker, but was no good to me, unless I changed the front as well.
   / Massey 1440 rear ring and pinion. #4
Might try Tractor House for salvage units or Midwest Tractor salvage. The older they get the more orphaned they become.
   / Massey 1440 rear ring and pinion. #5
I'll try those places. Thanks.
Do you remember where you found the bolts? I'll need those too.
Thanks!!
I ordered through my dealer
   / Massey 1440 rear ring and pinion. #7
I believe there was a bulletin on this that involved some harder bolts or maybe different ring gear with larger diameter bolts - might ask a dealer.
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
2021 QUALITY CARGO, LLC QUALITY CARGO, LLC (A52472)
2021 QUALITY...
2000 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
2000 HEIL TRAILER...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
