Massey 1440 rear ring and pinion.
   / Massey 1440 rear ring and pinion. #1
frankd1
Lucknow, Ontario
MF1440-4 ,MF/GC2610TLB
I have a 2004 Massey Ferguson 1440 compact tractor. 5 out of the 8 bolts broke holding the ring gear to the differential. Chewed some mark on the ring and pinion gear. Ring and Pinion are no longer available. Havent had any luck finding a used set. Anybody have one kicking around? Or know of one?
Thanks
Frank
   / Massey 1440 rear ring and pinion. #2
Thanks
Frank
Any luck? I have the same exact problem
No luck finding new or used ring and pinion for mine. The contact area was not really damaged. I removed the burs and polished with a stone, ordered new bolts and had a good contact patern with proper backlash.
It is working good. Is yours gear or hydro? Mine is gear and is a different ratio than hydro. I did find a burnt hydro at a wrecker, but was no good to me, unless I changed the front as well.
   / Massey 1440 rear ring and pinion. #4
Might try Tractor House for salvage units or Midwest Tractor salvage. The older they get the more orphaned they become.
   / Massey 1440 rear ring and pinion. #5
I'll try those places. Thanks.
Do you remember where you found the bolts? I'll need those too.
Thanks!!
I ordered through my dealer
   / Massey 1440 rear ring and pinion. #7
I believe there was a bulletin on this that involved some harder bolts or maybe different ring gear with larger diameter bolts - might ask a dealer.
2019 Kenworth T270 Truck, VIN # 2NKHHM6X3KM358768 (A51572)
2019 Kenworth T270...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2003 Ford F-350 Dump , VIN # 1FDWW36P63EC81092 (A51572)
2003 Ford F-350...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2013 BOBCAT S630 (A52472)
2013 BOBCAT S630...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
