massey 1260
   / massey 1260 #1
wulber0777
massey 1260 compact
hi just bought a massey 1260 compact pulling what hair i have left out it wont start turning over but wont kick into life may go back to hiring people in if my massey wont play :confused2:
   / massey 1260 #3
There is a MF forum here on TBN. Perhaps you may find some assistance there. Good Luck. Welcome aboard to TBN.
   / massey 1260 #4
WELCOME to TBN :)
I moved your thread to the Massey Ferguson Owning/Operating Forum.
   / massey 1260 #5
I know this sounds very basic but have you confirmed you are getting fuel at the filter?
   / massey 1260 #6
Are you turning the key to the left for 20-30 seconds before you try to start it?
   / massey 1260
hi yes fuel getting to filter just when it passes through pump no pressure thanks for your reply
   / massey 1260
hi yes checked plugs all good thanks for your reply
   / massey 1260 #9
sometimes the fule soleniod malfuntions. Typically you can hear it click when you turn the key and then again a few second after the motor is turned off. In your case where the engine is not firing, that is where I would start.
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
KUBOTA ZD326 ZERO TURN LAWN MOWER (A51247)
KUBOTA ZD326 ZERO...
74in FEL HD Round Back Bucket (A53472)
74in FEL HD Round...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
ECHO CS-3510 CHAIN SAW (A51248)
ECHO CS-3510 CHAIN...
