massey 1260
   / massey 1260 #1
wulber0777
massey 1260 compact
hi just bought a massey 1260 compact pulling what hair i have left out it wont start turning over but wont kick into life may go back to hiring people in if my massey wont play :confused2:
   / massey 1260 #3
There is a MF forum here on TBN. Perhaps you may find some assistance there. Good Luck. Welcome aboard to TBN.
   / massey 1260 #4
WELCOME to TBN :)
I moved your thread to the Massey Ferguson Owning/Operating Forum.
   / massey 1260 #5
I know this sounds very basic but have you confirmed you are getting fuel at the filter?
   / massey 1260 #6
Are you turning the key to the left for 20-30 seconds before you try to start it?
   / massey 1260
hi yes fuel getting to filter just when it passes through pump no pressure thanks for your reply
   / massey 1260
hi yes checked plugs all good thanks for your reply
   / massey 1260 #9
sometimes the fule soleniod malfuntions. Typically you can hear it click when you turn the key and then again a few second after the motor is turned off. In your case where the engine is not firing, that is where I would start.
Manac Walking Floor Trailer (A50322)
Manac Walking...
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2025 INDUSTRIAS AMERICA FT510 5' X 10' HYD DUMP TL (A51247)
2025 INDUSTRIAS...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A51247)
UNUSED CFG...
