3-Point Hitch Marking 3pt leveling arm so it doesn't drop
   / Marking 3pt leveling arm so it doesn't drop #11
I'm late to the game but you could always take a cue from what some manufacturers do to mark the center of extension for a hyd cyl.. etc.. Add a 'travel rod'
Hose clamp a stiff wire rod to the leveling fork. Crankt he fork down to what you consider max travel. cut the stiff wire at a point that will coincide with some visual reference.. an existing mark.. or the bottom of the crank assy.. etc.
Easy to remove, or reposition and non maring.. etc.
Soundguy
   / Marking 3pt leveling arm so it doesn't drop #12
The housing for my top link has a hole drilled near the ends. When the threaded rod is no longer visible in the hole, it's time to stop turning the thing.
Kawasaki Mule 2510 4X4 Utility Vehicle (A55853)
Kawasaki Mule 2510...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56435)
2016 KBH...
2017 BOBCAT T770 SKID STEER (A52709)
2017 BOBCAT T770...
2013 International TerraStar Enclosed Service Truck with Liftgate (A56858)
2013 International...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
