3-Point Hitch Marking 3pt leveling arm so it doesn't drop
   / Marking 3pt leveling arm so it doesn't drop #11
I'm late to the game but you could always take a cue from what some manufacturers do to mark the center of extension for a hyd cyl.. etc.. Add a 'travel rod'
Hose clamp a stiff wire rod to the leveling fork. Crankt he fork down to what you consider max travel. cut the stiff wire at a point that will coincide with some visual reference.. an existing mark.. or the bottom of the crank assy.. etc.
Easy to remove, or reposition and non maring.. etc.
Soundguy
   / Marking 3pt leveling arm so it doesn't drop #12
The housing for my top link has a hole drilled near the ends. When the threaded rod is no longer visible in the hole, it's time to stop turning the thing.
Deere 310L (A53317)
Deere 310L (A53317)
2015 Audi A4 Sedan (A56859)
2015 Audi A4 Sedan...
2011 John Deere Tractor (A55973)
2011 John Deere...
Case 1020 25ft Draper Head (A55315)
Case 1020 25ft...
2022 JOHN DEERE 624P WHEEL LOADER (A52709)
2022 JOHN DEERE...
Portable Restroom (A54865)
Portable Restroom...
