Markham toothbar and ebay grapple
/ Markham toothbar and ebay grapple #1
wickedinhere
Kinder, Louisiana
Kubota L2800/LA463
I finally got a break from all the rain and installed my toothbar this morning it fits great. It will make a good accessory with the grapple when it dries up i will see how good it works.
/ Markham toothbar and ebay grapple #4
A tooth-bar and grapple are two add-ons that really make a difference in all the extra jobs that you'll be able to do much easier.
/ Markham toothbar and ebay grapple #5
I 'm thinking about getting a toothbar too. One question....will the bucket sit flat on a hard suface with the toothbar on the bucket? It looks like the teeth sit lower than the front edge of the bucket. If this is the case, wouldn't it be difficult to skim a pile of dirt off my lawn whithout digging down into the sod?
/ Markham toothbar and ebay grapple #6
Yep, that is a problem with toothbars. You can no longer get the bucket lip truly flush with the ground. It is generally not an issue for digging but for scooping something up off the lawn or off a driveway you will leave about half an inch behind. The toothbar also limits effective use of FEL float position because once one of the toothbar tines hits something and tries to dig in there is a tendency for the bucket to "dump" which will then engage the rest of the teeth/tines and you are suddenly digging rather than skimming the surface.
Island tractor is right but its really easy to unbolt the toothbar so its not really going to be a problem for me. I dug up a pine stump last week and the tooth bar
made digging alot easier its worth every penny.
/ Markham toothbar and ebay grapple #8
wickedinhere said:
the tooth bar
Agree. It is not such a hassle to remove when necessary and the toothbar is indispensible for digging.
/ Markham toothbar and ebay grapple #9
I was thinking of calling Markham, sure looks nice. I've also been looking at toothbars that have slots at the mounting holes. If you need a quick pass with no teeth just pull the bar forward so as to get the shank notch released from the bucket edge and rotate the bar about the bolts back into the bucket and then you are toothless. Since all the forces on the teeth are taken by the tooth shanks that slip over the cutting edge of the bucket a slot should work. I'm sure Markham could do that mod when they build mine.
/ Markham toothbar and ebay grapple #10
wickedinhere said:
....when it dries up i will see how good it works.
I don't know if it is EVER going to dry up here in NY. I don't dare take my tractor out of the barn...I can't remember the ground ever being this wet!
Nice toothbar and grapple! Just wondering - what do you figure your total cost was? (if you don't mind my asking)
The total for the grapple was around 1000.00 thats using a wr long valve all parts included. The tooth bar was 280.00 shipped to me.
/ Markham toothbar and ebay grapple #12
shaley said:
...toothbars that have slots at the mounting holes. If you need a quick pass with no teeth just pull the bar forward so as to get the shank notch released from the bucket edge and rotate the bar about the bolts back into the bucket and then you are toothless. Since all the forces on the teeth are taken by the tooth shanks that slip over the cutting edge of the bucket a slot should work.
I have a toothbar like that and I NEVER KNEW that's why it had slots at the mounting points. :eek: I guess that's why we never stop learning.
I ordered mine from KC Canary in upstate NY but it was shipped to me direct from the manufacturer in Illinois. I ordered the 'light duty' which is heavier than any task I'll ever tackle with it. I'd hate to see what they call heavy duty. I bought mine through Mark Brucker at KC Canary at 800-920-7097. I paid under $300 delivered at the time and still think it's about the best money I've spent on any attachment or accessory. Now that I know about the slots' use, it's an even BETTER deal. ;) :D
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2000 Malibu (A62613)
UNUSED AGT 12EX-ATA MINI EXCAVATOR (A64281)
UNUSED AGT...
2025 Kivel 48in Forks and Frame Tractor Attachment (A61572)
2025 Kivel 48in...
Kubota SVL 97-2 Skid Steer (A65579)
Kubota SVL 97-2...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
