manure grinder???
/ manure grinder??? #1
kossetx
Platinum Member
TX
NH TC 40 A, AC 5020
Hello Folks,
I've been using a lot of manure and urine soaked hay lately to both improve my plants and to add to compost. Chopping this stuff up is a bit harsh on my 48 year old body when you do it in quantity. My arms are getting bigger but my waist climbs also??? Is there anything that I can make or buy reasonably that will help in breaking up dried manure and hay? The green stuff is put directly into the compost pile. I've been using a hoe or the old timey step edger to do it lately, and as much as I enjoy it I have my limits on what I will do for fun. :) I have a jimna chipper but I'm repelled at the thought of a 1100.00 shredder too.
Any thoughts?
As always, TIA, Mark
/ manure grinder??? #2
Just load it into a PTO driven manure spreader and don't drive. It will leave a pile of shreaded matter,and all you have to do is wait a few months, turn it 1-2 times, and it will be all composted down. Mike
/ manure grinder??? #3
Depending on the size of the piles (not sure if you are spreading first), could you not use a push mower or riding mower with a mulch kit (screen), or if larger pile - your rotary cutter, to shred/mulch this stuff?
/ manure grinder??? #4
I'm with vallyfarm- I went to a organic farming seminar a number of years ago and that's how they recommended turning compost piles.
/ manure grinder???
Thanks for the replies. Have you guys priced a manure spreader ? It makes a shredder look cheap.
I'm really looking for small scale. Thant's why I do it by hand. My 13 cows and 6 calves aren't reliable enough to buy anything expensive.
I was thinking about an old corn sheller.
/ manure grinder??? #6
Other option is to compost it dry with grass clippings. Have done that with old, dry horse manure. Layer it with fresh grass, wet it down as you layer it and it heats up and breaks down very quick.
/ manure grinder??? #7
Just a guess-but it seems to me a weed-whacker with one of those three-blade choppers would work well on the dry stuff.
The blades are not rigid-they swivel if they hit something too hard to chop. The hardware store sells a variety of replacement blades, including plastic and metal ones.
Another advantage is the sweeping action seems like it would blow the chopped (dust) away from your pathway as you work. Wish I had all that compost available for my garden.
/ manure grinder??? #8
I've used my tiller to fluff up composted manure. We don't have straw in it so that might get rolled up in the tines but it doesn't me long to cut out similar material that gets tangled up there.
/ manure grinder??? #9
Why not buy a used or new chipper/shredder? I have an old 5 hp gas powered one that works great for shredding leaves, hay, and it will chip branches tolerably well. Used you could probably get one for $250. The usually have two chutes, one on each side. The chipper chute has blades mounted in a flywheel and the shredder side has blades like a lawn mower.
/ manure grinder???
onthesuak, I here ya, I'm just waiting for the grass to grow.
Knotbored, That is also an option. I'm just wondering if it will spit the poop all over.
Larry, Tilling is out for me. I try to do everything notill so the machine to do that would be to costly.
Mygoatboy, I've been watching for one too, to no avail so far. Everyone want 500.00 for a 650.00 retail chipper. I kinda don't see paying 20% off for used and no warranty.
Thanks again!!
/ manure grinder??? #11
I kept wondering when this possibility would come up.
I keep thinking that there isn't any inexpensive way to do this.
/ manure grinder??? #12
I wonder if its even necessary to "break up" the hard "stuff".
You mentioned a compost heap, and anything vegetable put in there will break down into mulch, wet will decompose quicker, but the dry "stuff" will absorb all the moisture too.
Break up any big piles into concrete block size with a (borrowed) front end loader, and just don't let it build up for months next time.
By the way, I have put all sorts of manures into my garden, both green and composted. The horse manure does bring up more weeds, but even the composted area did also-hoeing three weeds per chunk of soil takes no longer then hoeing one weed per chunk of soil.
/ manure grinder??? #13
I'm thinking of composting hay from two round bale feeders with manure from the barnyard. To speed up the decomposition, I'll add some dry molasses to encourage the bio-bugs to come for lunch.
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2017 Bad Boy Outlaw XP 60in. Zero Turn Commercial Mower (A64553)
2017 Bad Boy...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63689)
2019 Cadillac XTS...
2019 Chevrolet Tahoe SUV (A64557)
2019 Chevrolet...
IRanch High-End Tricycle (A64119)
IRanch High-End...
