Manually moving a new cylinder stroke
   / Manually moving a new cylinder stroke #1
scottrh
I have new 2X4X1.25 DA cylinder[1] and need to open the stroke 1/2 way to get measurements. Should I be able to just remove the hose caps and somehow force the stroke to move outward? It is difficult pulling on it in my vice. Any suggestions are appreciated. Scott.
[1] https://www.surpluscenter.com/Item.asp?item=9-6466-04
   / Manually moving a new cylinder stroke #2
Yes it should move, but it will take some effort especially if brand new. Put a few drops of oil on the shaft near the seal and try twisting first to break the static friction. That tightness is what keeps the hydraulic oil in at a couple thousand PSI. I usually put a screwdriver through both clevis's, stand on one, and pull on the other.
   / Manually moving a new cylinder stroke #3
If you have an air compressor and a blow nozzle with a rubber tip, you are all set.
Is that the cylinder that you bought?
   / Manually moving a new cylinder stroke #4
Make sure the ports are open, and put some muscle on the pull.
Ok thanks everyone. i will try my air compressor. I have a good one.
Yes - i have that cylinder and others. Plan on cutting and welding it. Probably over thanksgiving or so. Good fall project.
   / Manually moving a new cylinder stroke #6
Be careful with that air, because if you add a lot of air pressure, the cyl rod just might let go and extend at a rapid rate, and if you are in the way, OUCH, or OH Crap.
   / Manually moving a new cylinder stroke #7
I will add that you may want to cover the port at the rod end with a rag. It is common to have some oil left over from assembly and it does like to shoot out all over the place. I do this everyday and forget :ashamed: that it is a new process for others.
thanks for the warnings too. the air works perfectly at 90 PSI. thanks again. Scott
2016 Kubota SVL 75-2 (A47477)
2016 Kubota SVL...
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
1987 CASE IH 9150 TRACTOR (A53843)
1987 CASE IH 9150...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
