Manually moving a new cylinder stroke
   / Manually moving a new cylinder stroke #1
scottrh
I have new 2X4X1.25 DA cylinder[1] and need to open the stroke 1/2 way to get measurements. Should I be able to just remove the hose caps and somehow force the stroke to move outward? It is difficult pulling on it in my vice. Any suggestions are appreciated. Scott.
[1] https://www.surpluscenter.com/Item.asp?item=9-6466-04
   / Manually moving a new cylinder stroke #2
Yes it should move, but it will take some effort especially if brand new. Put a few drops of oil on the shaft near the seal and try twisting first to break the static friction. That tightness is what keeps the hydraulic oil in at a couple thousand PSI. I usually put a screwdriver through both clevis's, stand on one, and pull on the other.
   / Manually moving a new cylinder stroke #3
If you have an air compressor and a blow nozzle with a rubber tip, you are all set.
Is that the cylinder that you bought?
   / Manually moving a new cylinder stroke #4
Make sure the ports are open, and put some muscle on the pull.
Ok thanks everyone. i will try my air compressor. I have a good one.
Yes - i have that cylinder and others. Plan on cutting and welding it. Probably over thanksgiving or so. Good fall project.
   / Manually moving a new cylinder stroke #6
Be careful with that air, because if you add a lot of air pressure, the cyl rod just might let go and extend at a rapid rate, and if you are in the way, OUCH, or OH Crap.
   / Manually moving a new cylinder stroke #7
I will add that you may want to cover the port at the rod end with a rag. It is common to have some oil left over from assembly and it does like to shoot out all over the place. I do this everyday and forget :ashamed: that it is a new process for others.
thanks for the warnings too. the air works perfectly at 90 PSI. thanks again. Scott
2008  BIG TEX 16' T/A TRASH TRAILER (A53843)
2008 BIG TEX 16'...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
PRINTER (A53843)
PRINTER (A53843)
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
