Snow Equipment Owning/Operating Manual trans for snowblowing?
   / Manual trans for snowblowing? #21
I'm in the process of making a new purchase (tractor) for my business. I'm considering the Mahindra 2516 gear drive or a B2320 maybe a B2620 ( I got a very good price on the 2620) and I'm wondering if anyone uses a gear drive with a blower? If I use the 2516 for grass ( rear mount mower) or bush hog work it will not bother me to have a gear. I grew up using a gear and the shuttle shift on the 2516 is sweet. I have driven the Mahindra and found the gear to have very low speed in low range and power out the wazoo. I am concerned about using a blower with the trans driven PTO. The hydro is nice in this aspect but I love the gear for everything else I will do and loader work with the shuttle should be fine. What's the skinny on this topic? So all you gear drive fans and hyro users speak up please. My wife is in my butt about me being on the fence about the purchase. Plus if I get the gear she won't drive it!!
Scaper
Hydro would be ideal for a blower, but I've been running my Glide-Shift L4200 all season with a 6' blower, and haven't had an issue with speed. I usually run 2nd or 3rd (out of 8) - I've yet to have to resort to 1st, except once while chewing through about 18-20" of heavy stuff. Regardless of gear, if the blower starts to load up, just stand on the clutch for a few seconds. The live PTO mentioned earlier is a must-have though.
JayC
   / Manual trans for snowblowing? #22
Effective blowing means full pto rpm's at all times (or risk plugging). A hydro trans or super-creep allows that; normally geared trans will required start/stop or clutch slipping operation.
The money spent on the hydro (if its more) will be saved in time and clutches.
Absolutely true - if you are buying new and making a decision, I've vote to get a hydro. As much as I like my glide-shift, and I really do, my next tractor will likely be a hydrostatic.
JayC
   / Manual trans for snowblowing? #23
I live in the Muskoka area of Ontario where we normally get a lot of snow (not this winter though!) We have one of each and both work well but differently. Our Kubota 7510 is a gear trans non 2 stage clutch with a 54" snyder blower it will blow the full width and height of the blower and when approaching the end I do not touch the clutch but slip it into neutral. When the auger is cleared I step on the clutch, let the pto wind down and shift the trans. It is not perfect but works well and after 2000 hrs we have not had any clutch or tranny problems. Our L3400 HST with a 72" blower is certainly easier to do, as prevoiusly stated, just vary the ground speed as the depth of snow requires/allows. Both work but differently. Like the HST for blower and loader work, prefer the gear for most everything else.:confused2:
   / Manual trans for snowblowing? #24
I have to ask, do most of you actually believe this? Do you have any understanding of what it takes to wear out a tractor clutch? It doesn't seem like it.
   / Manual trans for snowblowing? #25
Gear is just fine. No need to over think it.
Same here. Just make sure you do have a creeper gear in reverse. My unit has a 16x16 tranny. Works great. But my tractor hp range doesn't offer a hydro option either. If the hydro had a speed lock that would help.
   / Manual trans for snowblowing? #26
Probably not, since most probably have no experience with gear transmissions...
   / Manual trans for snowblowing? #27
I have a 20hp/pto gear tractor and I run a 64" blower off the back. Low gear is the perfect speed for blowing snow. Yes, a bit slow but, when I am blowing it is clearing the full 64 inches. No 'fall in' snow from the edges of the blower.
Totally impressed with the efficiency of the blower.
And, by having a rear blower, I still have the capabilities of the bucket out front. Perfect set-up.:thumbsup:
   / Manual trans for snowblowing? #29
I fopund my Jinma to be good for blowing snow. It is a geared tractor with 16F / 12R with a creeper gear set up. I have H,L, fast and slow on creeper with four forward gears. With reverse I have four speeds plus the low and high in the creeper setup.
I think this is a good setup and the ranges are fine for me - and I have a lot of choices. I usually blow in reverse, either 1st high or 2nd or 3rd high creeper speed - depending on the section of driveway. It really isn't a problem using the gears as I set the engine revs at around 2200 rpm and that gives me great blower operation. Speed over the ground varies with the gears. I put the PTO into neutral when turning around with the blower lifted up - put back into gear once the blower is lowered again. Obviously the clutch is used for each operation/change, but it becomes second nature after a while and really isn't a problem. I guess if I were older (I'm 66 at present) operating the clutch might get to be a problem - but for now it is just fine.
I must add here in fairness, I have not used an HST or auto tractor, so I have nothing else to compare with.
Cheers
Jim
My drive varies from straight and level to curved and sloping both up and down. Depth of snow governs speed mostly. I find going slower gives better control and a straighter cut (TPH blower going in reverse).
   / Manual trans for snowblowing? #30
Well, I'm not sure. In addition to my previously mentioned snow removal experience (that sometimes consumes up to 60 hours per week) I have 30+ years of operating and maintaining clutched diesel powered vehicles weighing up to 37 tons in high speed emergency operations. I don't know if that counts on understanding how a clutch works and wears.
That is the reason that, based upon education, training and experience, I am personally aware of a number of one-hundred million dollar fleets that have switched out of clutched vehicles.
Now for ground engagement duties WITHOUT ground speed speed variation while maintaining full PTO rpm, well thats different. Without devaluing farming operations in any manner, all tractor use is not farming. The question was about snow. Your mileage may vary.
2006 Ford F-450 4x4 Service Truck (A56858)
2006 Ford F-450...
2006 Hackney T/A Hazmat Truck (A56858)
2006 Hackney T/A...
2015 Chevrolet Traverse LS SUV (A56859)
2015 Chevrolet...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
9000 (A47477)
9000 (A47477)
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
