Manual Thumb
/ Manual Thumb #1
sherpa
Platinum Member
North Carolina Mountains
2004 NH TC33D & 2014 NH Boomer 24
Does anyone sharpen the teeth on their manual thumb? My thumb seems to drop half the logs I try to pick up. The logs just slip right out.
/ Manual Thumb #2
Welding tusks on my thumb solved all that for me.
/ Manual Thumb #3
The curl should have enough psi applied to keep the log pinched in between the thumb and bucket of the backhoe.
I have seen where somone drilled an extra hole in the manual thumb bracket to have the thumb spaced for smaller objects.
No, I haven't and wouldn't sharpen the teeth as the hydraulics have enough force to grip objects.
Must be something going on here that is out of the ordinary?
@GeneV solution looks like a good fix.
/ Manual Thumb #4
I have no problem with my LS grabbing big or small logs.
/ Manual Thumb #5
No problem with my Kubota BH92 picking up logs or rocks. Have you tried a different setting?
Andy
/ Manual Thumb
OK, it sounds like an operator error. I will get me a couple logs of different sizes and practice picking them up with different settings. Thanks!
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
2018 John Deere 3033R (A64126)
2018 John Deere...
2007 Ford F-450 Flatbed Truck, VIN # 1FDXF46P77EA72394 (A65563)
2007 Ford F-450...
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
New 11'x19' Steel Carport with 10' open sidewalls  (A62679)
New 11'x19' Steel...
