Manual Thumb
/ Manual Thumb #1
sherpa
North Carolina Mountains
2004 NH TC33D & 2014 NH Boomer 24
Does anyone sharpen the teeth on their manual thumb? My thumb seems to drop half the logs I try to pick up. The logs just slip right out.
/ Manual Thumb #2
Welding tusks on my thumb solved all that for me.
/ Manual Thumb #3
The curl should have enough psi applied to keep the log pinched in between the thumb and bucket of the backhoe.
I have seen where somone drilled an extra hole in the manual thumb bracket to have the thumb spaced for smaller objects.
No, I haven't and wouldn't sharpen the teeth as the hydraulics have enough force to grip objects.
Must be something going on here that is out of the ordinary?
@GeneV solution looks like a good fix.
/ Manual Thumb #4
I have no problem with my LS grabbing big or small logs.
/ Manual Thumb #5
No problem with my Kubota BH92 picking up logs or rocks. Have you tried a different setting?
Andy
/ Manual Thumb
OK, it sounds like an operator error. I will get me a couple logs of different sizes and practice picking them up with different settings. Thanks!
2017 Kenworth T680 (A64127)
2017 Kenworth T680...
KMC 3pt 6 Row Peanut Reshaker (A64127)
KMC 3pt 6 Row...
LOT OF SCRAP IRON AROUND CEDAR TREE (A63291)
LOT OF SCRAP IRON...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
2005 TerraGator 8104 (A63688)
2005 TerraGator...
