Mantis 2-cycle rotor tiller priming bulb problem
   / Mantis 2-cycle rotor tiller priming bulb problem #1
jayhawk238
Featherville Idaho
2004 Kubota L5030
The priming bulb on my tiller is not working right. When I push the bulb and then release it takes over a full minute to recover and it appears it is not drawing and fuel. Which, of course will not allow me to start the tiller. Any ideas on how to fix this problem? :confused:
   / Mantis 2-cycle rotor tiller priming bulb problem #2
You could try to take the carb apart and clean it ,but the plastic primer pump can't be taken apart.I just tossed mine and bought a new one off Ebay ($10)
   / Mantis 2-cycle rotor tiller priming bulb problem #4
You need to replace with new one. You can buy online. Just search around. Fairly common part. Mantis uses Echo 2 stroke engines. A local small engine shop or power equipment dealer should also be easily able to get part.
Thanks! I'll go to Ebay and look for one.
Thanks! That sounds like the way to go.
   / Mantis 2-cycle rotor tiller priming bulb problem #8
i have had several of those mantis tillers. they sure are useful little guys.
Peterbilt 377 Semi-Truck (A53473)
Peterbilt 377...
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
UNUSED Single Stall Portable Restroom (A53117)
UNUSED Single...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
