Mantis 2-cycle rotor tiller priming bulb problem
/ Mantis 2-cycle rotor tiller priming bulb problem #1
jayhawk238
Featherville Idaho
2004 Kubota L5030
The priming bulb on my tiller is not working right. When I push the bulb and then release it takes over a full minute to recover and it appears it is not drawing and fuel. Which, of course will not allow me to start the tiller. Any ideas on how to fix this problem? :confused:
/ Mantis 2-cycle rotor tiller priming bulb problem #2
You could try to take the carb apart and clean it ,but the plastic primer pump can't be taken apart.I just tossed mine and bought a new one off Ebay ($10)
/ Mantis 2-cycle rotor tiller priming bulb problem #4
You need to replace with new one. You can buy online. Just search around. Fairly common part. Mantis uses Echo 2 stroke engines. A local small engine shop or power equipment dealer should also be easily able to get part.
Thanks! I'll go to Ebay and look for one.
Thanks! That sounds like the way to go.
/ Mantis 2-cycle rotor tiller priming bulb problem #8
i have had several of those mantis tillers. they sure are useful little guys.
/ Mantis 2-cycle rotor tiller priming bulb problem #11
Couple of possibilities. Newe models have an air vent line coming out of the tank with a white object at the end. Looks like a filter. Could be plugged. With the gas cap on tight, it won't pass fuel. Older ones have a tank vent. Same issue.
Make sure you have the fuel supply and return lines connected correctly. If they get switched, you'll be sucking air from the tank.
I just bought a whole new carb for a neighbor's Mantis. $10.95. Free shipping off of ebay. Works wonderful.
Informational Lot - Financing (A63688)
Informational Lot...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
Deere 700K (A64126)
Deere 700K (A64126)
2007 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2007 MACK CHN613...
2022 EZ-GO ELITE...
ATS Mini Excavator (A66285)
ATS Mini Excavator...
