mamafudge
   / mamafudge
You need to tell us more about the nature of the problem in order to get any useful advice.
Steve
No power to lights, instruments, or starter. Started to repair by replacing battery.checked fuses appear good. wires look connected. There is a wagner dot fuse about the size of a ping pong ball.i dont know what it does or if it is good.
   / mamafudge #5
Dd you remove both ends of both battery cables and clean them bright? Often guys get enough juice to start but when they replace the batt the cable gets moved enough to break contact. Or, maybe an instrument panel ground?
Jim
   / mamafudge #6
Clean & tighten all 4 battery cable connections.
   / mamafudge
Jim
Thanks Jim I will check both. Instrument ground sounds possible
   / mamafudge
Ah. Didn't check other ends. Might be right. Makes sense. Thanks
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
J and L Cargo Express Shadowmaster Enclosed Trailer (A53472)
J and L Cargo...
2021 KUBOTA SVL75-2 SKID STEER (A51246)
2021 KUBOTA...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
UNUSED CFG INDUSTRIAL MX20R EXCAVATOR (A51247)
UNUSED CFG...
