Making switch from Green to Orange
   / Making switch from Green to Orange #31
My opinion is I think kubota makes the loader lever intentionally long....so you can taylor it to what works best for you.
Again, all what you are used to, but when I get on a machine that has the lever mounted by the seat or on the fender it feels awkward to me. And one of the benefits is the valve is directly controlled by the lever. No cables or remote mounted valve that have cause so many people issues
Man that is actually a really good point.
My old Cub Cadet had the lever directly on the valve up on the loader mount, and I could really feather that thing and do two functions at once like a pro.
My new Kioti has the lever on the fender, which I thought was going to be a huge plus. When sitting down nice and relaxed, and just moving loose materials around, sure, it's great - right at your fingertips with arm on the armrest. But the minor slop in the control cables makes it harder to quickly control minor adjustments. And then if I need to stand up to precisely view my SSQA fork tips, now I have to bend/crouch over to reach back down to the lever (thinking about making it longer/taller).
I am curious what you plan on running on the back (other than the backhoe) that you wanted no less than 40HP
The treadle is natural for me. I hop on anything other than a kubota and it takes me a minute and some thinking to not make a mistake. You will adapt and it will feel natural in no time.
Nice machine and pretty much the same step up I made in terms of size and capability when I went from a L3400 bota to a MX. They are quite a bit more capable
The biggest reason for the PTO horsepower is that I run a wood chipper. My old tractor was about 30 at the PTO and was a little challenged for that. If I had found a great deal I could have lived with less than 40, but I had set that spec as a guideline when I did my search. I am also the kind of person who typically buys and owns something for a long time. I have a 1990 Dodge cummins diesel I bought new in May of 1990 and still drive...LOL. My last tractor was a JD that I bought new and owned for 22 years. So when I made this investment I wanted to make sure it would meet current and future power needs as it will definitely outlive me.
It definitely varies from one machine to the next. I was used to the fender mounted lever on my old one. It didn't use cables though, as the valve was right underneath it and it was directly connected. I am getting more used to the location I have now, and of course they all have pluses and minuses.
   / Making switch from Green to Orange #34
Made the first mods to the new machine today. I welded on some chain hooks on top of the bucket. I also drilled a hole in the leading edge. I did this on my old machine so I could stick a hitch ball in there. It is really hand for moving trailers around on the property. While I was at it I went ahead and fabbed a chain hook that would mount there as well if I wanted to lift from bottom edge of bucket instead of top. I also found out there apparently is a big shortage of equipment matched paint right now. No Kubota orange to be found around here at least. So for now I painted with Rustoleum orange. It is a lighter orange but will do to prevent rust until I get some to match. Pics attached.
Tractor Supply has the Majic spray cans of Kubota orange, but it takes FOREVER to dry. When I got new ballast box couple weeks ago, it was red. So when I was in Ace hardware looking for something, I looked in paint aisle. No Kubota orange color spray paint, but Ace had their own brand of Allis Chalmers glossy orange. It was on sale at time, but normally $5.99 for a big can. It is pretty close to Kubota orange and looks pretty good on the ballast box...it also dried pretty fast....
   / Making switch from Green to Orange #35
That is an awesome tractor. As for the treadle pedal, I am getting used to mine after 8 months. Reverse takes effort in the B2601! I may have weakened the spring by chocking the pedal with a piece of 2x4. But I think it's mostly that my body has adjusted.
OK all you other Kubota HST owners, here is a question for you. I have had this MX5400 just a short time and it is my first Kubota. Today I was picking up some debris out of the yard and putting in the loader to take to my burn pile in the field below the house. I was stopped on a fairly steep incline. I had the trans in high range. When I started to pull up the hill it pulled the engine down a little at first but then just slipped. The revs stayed up but when I pushed on the forward direction pedal it didn't stall the engine but kept reving but not moving. It was just like you were driving a car with the clutch slipping. I put it in mid range and it pulled right on up. After that I thought, maybe I had inadvertently bumped the range selector in neutral. So I drove around to the same spot and tried it again. Same result. The JD HST I previously owned would not do this. If you tried to go up a steep incline in high range and it wouldn't do it, it would just stall the engine, but it definitely wouldn't just sit there and rev and not go. Is this normal for the Kubota HST? It runs perfect otherwise, I just found this a little strange.
   / Making switch from Green to Orange #37
My HST would load the engine. It would not do what you have described.
   / Making switch from Green to Orange #38
OK. We have the same engine, but I don't know how much help my description will be because we have different transmissons. But they are both Kubota HST trannys, so see if any of this sounds familiar when taking a load up a hill.
I'd say that what you describe is about normal for my HST+. If the hill is too steep and I am in too tall of a gear it simply will not make any progress - and it won't speed up - especially if I slow or stop and then push down the pedal all the way down like I normally do. What happens instead is the engine revs up but not all the way, although it definitely won't stall. From the way the engine sounds and the whine of the HST the tractor is certainly feeling a load, but instead of speeding up we are slowing down...way down. We may continue up just slightly moving, but it sure feels & sounds like tractor abuse.
Now if I let off on the HST pedal it will stop laboring the engine and whining so much....AND we will go just slightly faster, but still you can tell the engine and transmission just aren't in sync or happy with each other... The engine RPM are too high and the speed too low and the whining too loud.
That's about when I slap myself, apologise to the tractor, and select the next lower range. Then it all quietens down and goes right up like it was on flat ground.
rScotty
   / Making switch from Green to Orange #39
Mine is a MX5100 that is 9 years old. So I dont know what if any changes were made to the HST and/or if they have incorporated some type of stall guard or auto-throttle in the MX line.
But with mine, in high gear and loaded or on a hill....It will slow the engine down if I try to give too much pedal. Back off the pedal (lessen the HST demand) and the revs come back to whatever I have the throttle set at. That may or may not be enough to move the machine and if it does it may be slow.
If you are unfamiliar with hst and have never driven one they take some getting used to.
Instinct from every other piece of equipment says that when you start to load up and need more power you need to push the go pedal harder. HST is just the opposite. When the engine starts bogging or loading up.....you need to back off the pedal to let the engine catch up with the HST.
Again....if it has some type of anti-stall feature....the tractor may be doing that for you even though you have the pedal pushed....which is why your RPM's are coming back
Komatsu D39 PX Crawler Dozer (A57453)
Komatsu D39 PX...
20ft Shipping Container (A57453)
20ft Shipping...
2013 NISSAN NV3500 CARGO VAN (A59575)
2013 NISSAN NV3500...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
1991 Snowco Trailer (A59814)
1991 Snowco...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
