Making sense of Quick Disconnects
   / Making sense of Quick Disconnects #1
canoetrpr
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
I am installing a Prince SV stackable valve, with 4 spools on my Kubota L3400. The work ports are SAE 8 i.e ORB 8 and are located on the top of the valve. I was planning on having 90 degree elbow fittings on my work ports and then attaching one end of a QD to each of the work ports.
For space, I was thinking of using the longer elbows on the ports on the rear and shorter ones on the ports on the front - so every valve stack would have one short elbow fitting and one long one. Figure I'm going to have to muck around a bit to to get a setup that will allow me enough space to get 8 quick disconnects on there (I have 4 stacks). I might need some 45 degree elbows instead.
I was planning on having 3/8 hoses with JIC -6 female swivel's on the ends.
Here's where it gets tricky. I had no clue that there were several different standards for quick disconnects. Best I can tell, these three are the most popular:
ISO 7241-1 Series A Hydraulic
ISO 7241-1 Series B Hydraulic
ISO 5675 Agricultural
Question 1: Why would one choose one of these three over the other?
Question 2: I can't for the life of me find any of these quick disconnects that will accept anything other than a NTPF. I thought NTPF was somewhat outdated, which is why I was going to go with JIC females on my hoses. Seems like I'm going to need a JIC to NTP adapter on my hoses to get quick disconnects on them.... does this make sense?
BTW, after I'm armed with the information I need, I will be heading into a local hydraulics shop to ge the hoses made and fittings bought. Just want to be prepared with all the information I can get before hand.
My project is FINALLY getting under way.
   / Making sense of Quick Disconnects #2
I used fittings to space my QD's apart, I just took the valve to the shop with me and they helped me...
I used QD's that matched my FEL just to keep everything the same...
kennyd, thanks for posting your pictures. You've got pretty much exactly what I had in mind. You've basically made a longer elbow for the set of ports towards the front of the tractor.
I swear I saw double and triple length elbow fittings sold as is but if I can't source them locally, or if they are not long enough to allow enough room for a QD, I'll do exactly as you did.
Love the mounting job you have done. I'm still trying to sort through exactly how to mount cleanly.
   / Making sense of Quick Disconnects #4
Thanks, You can view the whole thread with more pictures HERE
Kennyd - did you actually paint that valve to match your ROPS? I'm also a bit surprised that your valve didn't come with the handles. Sure hope mine does - as I have no plans to make them!
   / Making sense of Quick Disconnects #6
Yes, I did paint it...It was a Surplus Center "deal", that's why it came without handles-I don't think they even sell it anymore.
   / Making sense of Quick Disconnects #7
You could install these elbows below. They are -6 ORB X -6 JIC elbows. one long drop, other standard. There is also an extension on the long drop if you need more room.
   / Making sense of Quick Disconnects #8
I messed up. Here is the elbows without the extension attached.
Sorry about it being blurry, but I'm sure you get what I'm talking about.
WCH, that looks like exactly what I need.
Do you have any thoughts to share on the QD choices? Is it worth me putting on a ORB to JIC elbow given that QD seem to only take NTP? or are there QDs that accept JIC male?
   / Making sense of Quick Disconnects #10
There are ISO-A and ISO-B qd's out there that are ORB. You might want to consider flush face as they tend to be more compact and are readily available in ORB.
2018 John Deere 8370R MFWD Tractor (A53342)
2018 John Deere...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53472)
2016 KBH...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
