Making pivot pins - what kind of steel to use?
   / Making pivot pins - what kind of steel to use? #11
Check out McMaster Carr. They have hardened shafts that are annealed at the ends so you can machine them.
SAE 660 bronze is what you want for bushings if you go that route.
Bronze? I understand that bronze is not going to rust itself into the bushings (like the lower pins in my BX23 did) - but is bronze a suitable material for pivot pins? I'm not familiar with heavier duty machinery than compact tractors - is bronze used in some applications?
   / Making pivot pins - what kind of steel to use? #13
I have made pins like that out of mild steel, drilled for grease.
The BH77 pin is almost totally encased in the side and center bushings, if I recall correctly, it would be difficult to break a 25mm mild steel pin.
But, for that non rotating application, I wonder if the answer might not be, a shot of some kind of high quality penetrating oil every 10 hours when you grease the tractor.
2019 CASE IH 580S QUAD TRAC TRACTOR (A52707)
2019 CASE IH 580S...
John Deere 1025R (A53317)
John Deere 1025R...
UNUSED FUTURE HYD 12" AUGUER (A57193)
UNUSED FUTURE HYD...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
ATLAS MD785 7' ROTARY MOWER (A57192)
ATLAS MD785 7'...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
