Making pivot pins - what kind of steel to use?
   / Making pivot pins - what kind of steel to use? #11
Check out McMaster Carr. They have hardened shafts that are annealed at the ends so you can machine them.
SAE 660 bronze is what you want for bushings if you go that route.
Bronze? I understand that bronze is not going to rust itself into the bushings (like the lower pins in my BX23 did) - but is bronze a suitable material for pivot pins? I'm not familiar with heavier duty machinery than compact tractors - is bronze used in some applications?
   / Making pivot pins - what kind of steel to use? #13
I have made pins like that out of mild steel, drilled for grease.
The BH77 pin is almost totally encased in the side and center bushings, if I recall correctly, it would be difficult to break a 25mm mild steel pin.
But, for that non rotating application, I wonder if the answer might not be, a shot of some kind of high quality penetrating oil every 10 hours when you grease the tractor.
(2) USED 7000 LB AXLES W/ BRAKES (A57192)
(2) USED 7000 LB...
2023 Kubota L6060HST Compact Utility Tractor (A55315)
2023 Kubota...
Carry-On 6'x8' Trailer (A53316)
Carry-On 6'x8'...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
USED 3500 LB TRAILER AXLE W/ BRAKES (A57192)
USED 3500 LB...
2010 Ford F150 (A55973)
2010 Ford F150...
