Oil & Fuel Making oil
   / Making oil #11
It can still run good with a bad injector running fuel past the rings.
It is pretty easy to tell if there is fuel in the oil. Rub a little oil from your dipstick between two fingers. If only oil it will be slick like oil should be. If it has fuel in the oil it will be less slick and will 'clean' your fingers so that it feels like there is almost nothing between them.
   / Making oil #12
umbrella seals can leak on an injector pump, depending upon design of course..
   / Making oil #13
Could it be the fuel pump? Took the injector pump apart and see no seals whatsoever that would let fuel leak into crank case. Am sure it is diesel not hydraulic oil. Changed oil again, ran for 3 hours and it added about 10 ounces to the gallon of oil I used. Fuel pump bolts into the crankcase sump, think there must be a seal on the fuel pump plunger, if it is bad, think fuel would leak into crankcase.
That's what happened to my JD 820. New fuel pump fixed the problem.
   / Making oil
Thanks for the reply, ordered a new fuel pump, will post the results.
UNUSED FUTURE HYD WOOD DRILL (A57192)
UNUSED FUTURE HYD...
2017 Ford Taurus Sedan (A55853)
2017 Ford Taurus...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
405 (A52706)
405 (A52706)
2018 Ford Escape SUV (A56859)
2018 Ford Escape...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A57193)
UNUSED FUTURE SKID...
