Making my own tire chains
   / Making my own tire chains #1
Bspring
SC
I have a JD 3320 with R4s that is about worthless when the ground is wet. I either need to go with R1 tires or put chains on the R4s. I priced chains and was shocked at what they wanted for them. Why can稚 I make my own? I have done this before on our lawn tractor and they worked great. I would just buy a roll of chain measure it out and weld it up. Is there any reason this would not work on my tractor?
   / Making my own tire chains #2
Factory chains are hardened, only the cross links not the side stringer, to reduce wear, if your only using them in dirt/mud should be OK but would not last long on paved surfaces, even the hardened ones wear pretty quickly. You could use those repair links instead of welding, that would speed things up.
They do make a huge difference, I mostly use chains in snow but was recently using my 2 WD tractor in the woods with new v-bar chains 4 link spaced, the ground was very greasy after some flooding rains, I was surprised how good it went pulling logs and pushing tree tops through the mud, I'm sure it would have gotten stuck just driving in there with out chains.
I know about the shock of the cost of chains at the dealer, mine wanted close to $500. for a set of rears.
I got a killer deal on chains I found through Graigslist close to my town, guy owned an auto parts warehouse and had several pallets of surplus chains, I walked out with 5 pails of chains for $150. had to mod some but others were perfect fits. Made 3 sets of large rears, and 4 sets of fronts and garden tractor rears.
I looked and looked, asked everyone for used chains, couldn't find anything but got lucky with this find, there's still pallets of chains there but it's in CT.
Good Luck, JB.
   / Making my own tire chains #3
Made these for my Wheel Horse. Cost about $30.
   / Making my own tire chains #4
If you go to a place that sells equipment to city and county road departments you can buy cross chain links in bulk. You re-use the side chain and replace the cross chains. The chain is hardened and you can put the link you want to cut in a vice and snap it off with a pipe wrench by twisting the link. They also make a tool that looks like bolt cutters to spread and clamp the links that attach the cross chains to the side chain. We have done this for years to keep chains made up for dump trucks and a road grader to push snow.
How do you have room for chains on the rear? I have the large R-4s on my 3320 and you can't even stick your hand between the tire and the fender. I am going to have to make a set of wheel spacers to get chains to fit.
Dan
   / Making my own tire chains #6
I made my own set for my Ford Ranger many years ago. I was too cheap to buy twisted link chain so I bought 1/4" straight and twisted each one by hand (more time than money :)). If I did it again I wouldn't bother twisting the links - apparently the straight links work better than twisted (for traction not wear). They worked very well and I have no problem with wear on the softer steel but I never use them on pavement. They are now permanently installed on my old Suzuki SJ410:cool:.
You could make your own; the hardened chain is nice but may not be necessary if you don't run pavement. I think the price from tirechains.com is pretty good, hard to match the price buying the parts yourself - it's the shipping (and import to Canada for me) that would cost too much.
   / Making my own tire chains #7
Dan
Not sure about the 3320, but on my 4310 you gain about an inch or so by reversing the wheels, just enough to get a safe clearance for chains, there are some hydraulic lines very close so you do have to be careful.
   / Making my own tire chains #9
You will definitely want these if you are doing it with the traditional cross links. Welcome to Labonville.com - Logging Supplies and Safety Apparel
You can find them cheaper sometimes, but after you swear and cuss and skin a few knuckles you will wish you had some.
The other option is s-hooks to connect chain to the side chain. These are great as they allow chain to rotate and wear evenly on all sides. Prevents the edges from wearing in one spot before the rest of the chain is worn out.
Available here: Parts For Tire Chains
   / Making my own tire chains #10
Just as an FYI--I've got the large R4's on my 3320 and have a set of chains from TireChains that fit with no problem--and greatly increase the traction and usefulness of the tractor in the winter.
2011 Chevrolet Malibu Sedan (A50324)
2011 Chevrolet...
2021 Dodge Durango SUV (A50324)
2021 Dodge Durango...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Super Material Lift MH1000 (A52128)
Super Material...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2007 CHEVROLET SILVERADO 4X4  DUALLY TRUCK (A51222)
2007 CHEVROLET...
