making land smooth...
   / making land smooth... #1
tsavoy01
scott la
mahindra 4530
i have a few acres of pasture that is flat like a typical hay field, and smooth enough to drive on, yet the land isnt perfectly smooth, there is little bumps spread all over. i would like to make it smooth enough for an airplane run way. all i have is a 6 foot disc, boxblade and scraper blade. what would be the best way to make it smooth? would one of those heavy rollers work?
:confused::confused:
   / making land smooth... #2
I use a piece of hurricane fencing,, 6’ by 10’ with some old railroad timbers laid across and tie down,, drag it with my tractor.. It will get as smooth as you would like.. Lou
well what about grasss? i still have grass growing on it. so its holding all the dirt together
   / making land smooth... #4
You need it not only smooth, but flat, for higher speeds. That usually means something long.
Here are two ideas I've collect, probably from TBN.
Extend your rear blade:
Build a float:
Bruce
   / making land smooth... #5
It will slide over the grass.. it will cut the high spot down.. I use it in my hay fields in the spring if I have to many crawfish mounts.. Lou
ahhh ok, i see. yea the bumps in my field arent tall enough to be grabbed by any thing like that. :confused3:
   / making land smooth... #8
If you are looking for runway smooth bring in a road grader.
   / making land smooth... #10
If light planes are using it, speeds will be in the vicinity of 60-75 mph, with relatively tiny wheels, like 5.00-5 and 6.00-6.
Bruce
2019 CATERPILLAR 299D2 XHP SKID STEER (A51246)
2019 CATERPILLAR...
UNUSED CFG MX15RX EXCAVATOR (A51247)
UNUSED CFG MX15RX...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2005 CHEVROLET EXPRESS CARGO VAN (A53426)
2005 CHEVROLET...
TROYBILT TB51BP GAS BACKPACK BLOWER (A51248)
TROYBILT TB51BP...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
