Making concrete from crusher run?
   / Making concrete from crusher run? #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
Has anyone tried doing this? I don’t really want to get small gravel and sand. I have plenty of crusher run already. I was thinking about mixing the crusher run with Portland cement. I don’t need it to look good and peak strength isn’t really a priority. If I got even 1000 psi from the mix I would be happy. I plan to load the crusher run and cement into a mixer and mix it not brush the cement dust on top of the gravel.
   / Making concrete from crusher run? #2
It's done all the time here at the local concrete plant. I had my concrete driveway replaced and the contractor took the pieces to the plant and I got some of it back mixed into the new batch after washing. Not as strong as stone.
   / Making concrete from crusher run? #3
I was considering that to cut down on the dust for a sidewalk.
I figured I would have to add a little sand to the mix it would save me a lot of work.
   / Making concrete from crusher run? #4
If it has fines in it that’s not normally used to make concrete. Would it work? Try it and let us know.
   / Making concrete from crusher run? #5
What are you using the concrete for. Dust is. Not usual ingredient in concrete
   / Making concrete from crusher run? #6
Some guy gave my dad a formula for mixing concrete that ultimately failed. I got the privilege of busting it up with a sledge. I don’t recommend experimenting when it comes to concrete. Stick to proven materials and methods.
   / Making concrete from crusher run? #7
3 sand 2 stone 1 concrete
I imagine the crushed fines could replace the sand
   / Making concrete from crusher run? #8
Watch out for steel wire mesh and your tires
This is crushed limestone not recycled concrete.
   / Making concrete from crusher run? #10
Might work for pavers etc. But the dust is going to kill any strength.
Unless you can wash it!
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
2021 JCB 1CXT Skidloader/Backhoe (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 JCB 1CXT...
Stage Line Trailer (A50322)
Stage Line Trailer...
2003 CATERPILLAR 420D BACKHOE (A51242)
2003 CATERPILLAR...
John Deere A Tractor (A50514)
John Deere A...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
