Making a much unloader for my trailer.
   / Making a much unloader for my trailer. #1
Jg1
Cub Cadet 7195
Not sure if this is the right place to post this?
I have an 8’x5’ utility trailer I would like to use for unloading mulch, wood chips and dirt. The tarp I have is from an old cargo unloader that I use to use for unloading wood from my truck. I see you can buy them from harbor freight so you have a picture of what I have. Instead of cranking it by hand I would like to use an electric winch that I have. I’ve seen it done on a video. The problem I have is my keyed hub is 1-1/4” (1.250) and the pipe it needs to go on is (1.275). It doesn’t seem like much but it is. I would like to drill out the hub so it can fit over the shaft but I don’t know what will happen when the flute of the drill bit comes in contact with the keyway. Do you think it will damage the hub? If anyone is familiar with making a bored hub with 1/4” keyway larger?
I would greatly appreciate some advice.
Thanks
   / Making a much unloader for my trailer. #2
I believe the drill bit will catch and chatter on that key way unless you have the coupling rigidly mounted in a good drill press or milling machine.
How true in diameter does the bore need to be?
I’m thinking it could be a little bigger because I’ll be using the key and it has a set screw. I’m using the hub and rim from a broken down golf cart I have. I need the rim to wind the winch cable on so the winch can turn the rim that’s attached to the pipe and unload the trailer. It’s not like I need to use it on the road. I don’t know, it probably could wobble a little bit.
The pipe looks like a black schedule 40 metal pipe.
I do have a good drill press and years ago I went to a garage sale where I bought a bunch of drill bits of sizes that you would never think existed. The guy was a machinist that had passed away. I have one that is
1-19/64” which is just a little bigger than the pipe. I guess I’m afraid of something breaking off and hitting me. I just wanted to know if anyone had done something like this or had some good advice.
   / Making a much unloader for my trailer. #4
Thanks
It probably wouldn't damage the hub, but it would almost certainly break or bind up the bit. Your best bet would be to take the hub to a machinist. Do you have a link to the video you reference? I'm not 100% sure I follow what you're trying to do.
If the link doesn’t work, I’ve attached a picture from the video.
   / Making a much unloader for my trailer. #6
Sounds to me like you need to invest in a used manure spreader and use that to unload your product and eliminate all the hassles.
I would like to use what I have lying around. Besides, the manure spreader wouldn’t be roadworthy to pick up wood chips, black dirt or gravel for my driveway. I’m retired and it gives me something to do in the winter.
   / Making a much unloader for my trailer. #8
If you can rigidly clamp the keyed hub in your drill press and control bit feed rate you might be able to drill the coupling if it is not hardened. I would still be concerned with the bit chatter and or catching and trying to screw itself into the coupling.
   / Making a much unloader for my trailer. #10
I have the HF unloader. As long as the tarp is not overloaded, the hand crank is actually pretty easy to wind.
If your objective is to install a large hub to drive the roller, why not attach a pipe of the appropriate diameter to the hub and drill a pin to mate up to the unloader?
The guy in the video appears to have welded some kind of hub to a rim that is connected to some kind of pipe being used as a roller. It doesn't look like he is actually using the HF roller that I can see.
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A54865)
New/Unused 14ft...
MISC TOOLS (A55745)
MISC TOOLS (A55745)
2012 Chevrolet Traverse LTZ SUV (A53424)
2012 Chevrolet...
New/Unused 78in Quick Attach Skid Steer Grapples (A54865)
New/Unused 78in...
2016 Ford F-150 4x4 Pickup Truck (A55852)
2016 Ford F-150...
2019 JOHN DEERE 325G SKID STEER (A52706)
2019 JOHN DEERE...
