making a custom flatbed truck side rail for a friend
   / making a custom flatbed truck side rail for a friend #1
grsthegreat
Super Star Member
north idaho
Kioti DK45SE hst cab
a friend of mine got a great deal on a f450 flatbed truck to tow his equipment for his business. he decided he wanted a custom side rail made to contain all the stuff piled u0p back there. had to have a removable 52" tailgate to allow for a work station.
he wanted it plasma cut similar to my driveway gate. i put it off until the temps got to be super frigid (wind chill -10F) just to make life more miserable. so we moved it into my shop. i had to move some stuff around to fit that fat as* truck, but we got it in.
first step was to design and cut the panels. these will be made of 8 gauge metal and fit into some 1/4" angle iron frame. than it will be powder coated and then attach a solid rear plate in a light color to display the powder coating. have not picked colors yet.
then we had to design a removable framework that bolted to the side rail. he wants it fully removable. we designed 4 SS bolts and a rear channel for stability. seems to work real good, and boy is it sturdy.
today we worked on a removable tail gate system. used some weldable barrel bolts, and they work great. when door folds hinges are out of the way of the bed. you can easily slide door off if you open it 1/2 way, but not if door is closed or fully open (going to install a block to prevent door from sliding when fully open). i have to finish cutting artwork and installing panels on Sunday.
   / making a custom flatbed truck side rail for a friend #2
Looks great nice job......
   / making a custom flatbed truck side rail for a friend #3
Looks good!
Hopefully great deal doesn't mean hidden 6.4L problems.
   / making a custom flatbed truck side rail for a friend #4
Looks great.
   / making a custom flatbed truck side rail for a friend #5
Might want to keep close eye on de SS bolts into mild steel if truck runs in salt & road brine. Reaction is near as bad as SS against aluminum. So called dielectric coating don't help either.
Really, ill have to look into that. Thanks
   / making a custom flatbed truck side rail for a friend #7
Called electro galvanic corrosion, plenty information on line. Weird thing de SS start to rust and erode away.
   / making a custom flatbed truck side rail for a friend #8
And here I was happy with my wooden sides UNTIL NOW!!!
Looks great.
   / making a custom flatbed truck side rail for a friend #9
Fantastic work.... great attention to detail.
How do you plan to latch the tailgate?
Several options available. Will get some pictures of one idea later today. There is absolutely no movement on either side when trying to rack the sides, so any latch should do fine. Door has edge to prevent moving onwards towards bed.
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
ALLISON TRANSMISSION (A55745)
ALLISON...
SUV (A59231)
SUV (A59231)
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
