Making 2 trailers out of 1...worth it?
   / Making 2 trailers out of 1...worth it? #11
I bought my 27 ft bumper pull (24 ft that someone welded 3 more ft onto) for 1600$ I had been looking for a bigger GN for a long time, all 5000-10000$.
   / Making 2 trailers out of 1...worth it? #12
Here's my suggested equation...
The value of this trailer in it's current state is the cost of new trailers minus the cost to re-build this one.
If you think you can get more out of this one than the equation above suggests it's worth, put it up for sale for a month. If you have any takers, you're golden. If not, you're re-building and posting lots of pictures and progress updates for us to marvel at.
Here's an example. If you can buy two new (or used) trailers for $3K each and it will cost you $4K to re-build this one, the difference is $2K. If you can sell this one for more than $2K you're ahead to just sell it and buy new trailers. I personally think you can find trailers for less than $3K, but I also think you can re-build this one for less than $4k, especially if you have the other axles already.
Switching gears here a bit...
Took a look at a trailer today maybe 1/4 mile down the road. I had been eyeing it a couple of times whenever I drove by. Met the owner yesterday and asked if he'd consider selling it. He said yes, so I mentioned I'd stop back over to take a look. Its only about 15 yrs old. Been sitting for 5-6 years. Made by Oklahoma Trailer Manufacturing, Inc. Gooseneck set up. It does have bolts to remove the sleeve and put a 5th wheel king pin I would assume. Its 25' long (20' bed with 5' beaver tail). 14k GVW. Deck looks fine and the tires should be fine unless they're just too old. I'd probably price it as needing tires, and if I can use what's on there for now, I'm in good shape. The guy is very nice and said he has to realize he'll never end up using it, and he'd be happy to see a neighbor make good use of it. It was his father's, and he got it after he passed away. He only used it a couple of times, mainly to haul back stuff from him father's place in OH.
Any thoughts? What do you think you offer someone in a situation like this? $750 seem unreasonable? Would it be a good idea to test the lights and brakes or just make and offer figuring on having to replace those too? I would expect to replace bearings from how long it has been sitting.
This would be a very ideal piece of equipment for me. I do believe the guy will be very very fair with me too. I already made the comment that if we're able to work out a favorable deal, I'd be happy to help haul something for him with in a reasonable distance. He seemed to be happy with that gesture.
   / Making 2 trailers out of 1...worth it? #14
That looks like it could work. You might think about offering him something for the trailer and offer to haul off the "debris" all around it.
This would allow you to cut the other trailer off for your friend and use metal from the front of the trailer or some of the metal in that debris to fix that 40' trailer in the conversion.
Then take all the excess metal and sell it for scrap. That would probably pay for any extras you may need and whatever is needed to "repair" the GN you want to keep.
   / Making 2 trailers out of 1...worth it? #15
750 seems a bit unreasonably low to me (least in this part of the country) for a trailer of that size and condition.
i see no reason why the bearings would be bad and would be MUCH more worried about the rubber on the tires before i was about the brakes or bearings.
   / Making 2 trailers out of 1...worth it? #16
I would plan on tires, brakes, and bearings plus my bet is most the lights are not working plus a new brake-away battery. YOU will need to put $750 into it to get it safe and road legal.
Chris
Chris
That's along the lines of what I was going to tell him. But I would certainly think the total for those would exceed $750. The tires alone would probably be $400-$500
   / Making 2 trailers out of 1...worth it? #18
I did a trailer project along the lines of what you are talking about. I cosider myself a qualified trailer builder, only because I have built several, and modified several more. I work cheap, have a considerable junk pile and steel rack to pull supplies from, and it is still a lot of work, and time consuming. The other side as far as time, is I have a regular job, so working on trailers was the afternoon job, not my means of providing bread, so consider that also. The last fact, is I am cheap, so spending large amounts of money on a trailer to replace one that I have that will work just as well with a few modifications is usually not going to happen.
Trailer #1 was a 27' deckover, modified to haul a pair of Conversion Vans behind an angle deck one ton truck. It was a lot of work, took several weeks of every night work. Because I was working "for" somebody, modifying my trailer to fit their needs, it had to work, to their approval before they wrote the check. Problems were simple, trailer was too short, simple plan, extend it 10' with matching metal. Problem two, axle placement. The normal placement for a trailer pair of axles for a trailer this length was considered and followed. Then the truck didn't like it loaded with the vans and placement had to be moved. Problem three was decking material. I purchased a used trailer to strip the floor off, but the timing wasn't working out, so I purchased bar grading to deck the trailer out with. Good move on my part, bad move for the buyer, as now the trailer weighed 4700 pounds empty. He took delivery and I got a call two weeks later about a D.O.T problem with his vehicle. Seems the 7700 pound truck and 4700 pound trailer were eating into his 25999 or less license, so I took the bar grading off and installed the original aluminum flooring from the purchased trailer.(weight now at 3300) Bottom line for this was, doing it and getting it exactly right takes a lot of planning and expertise, so expect setbacks as far as getting it right unless you are easy to please or a trailer guru.
Trailer #2 was a 45' fifth wheel boat trailer that I shortened to a 20' deck, and made 12' of it into a dump trailer. I call it my ugly dump trailer, because it is, but it does work great, didn't cost me a lot of money ($100) but it took several weeks of work, a lot of spare materials and some great help from a friend.
If selling the existing trailer was an option and purchasing what I needed was within my spending limits, I definitely would consider doing that, even if I had to kick in a little extra because modifying a large trailer is a lot of work, and takes a lot of effort to get it exactly right or your going to have problems with it.
David from jax
   / Making 2 trailers out of 1...worth it? #19
... Gooseneck set up. It does have bolts to remove the sleeve and put a 5th wheel king pin I would assume...
Something like this... PopUp Industries GN5 Gooseneck to 5th Wheel Adapter for 4" Round Coupler Tube There are other options including different sizes of square and round tubes depending on what the coupler on the new trailer is.
The other option is to get a gooseneck spider for your 5th wheel rails. Like this... SuperGlide Gooseneck Adapter 18K - Torklift Central
I went with the second option. I really like it. My daughter calls it the "goose bump".
Be careful bringing up different hitching options, though. It's a surprisingly emotionally charge issue. First thread I ever had locked on TBN was over trailer hitching options.
   / Making 2 trailers out of 1...worth it? #20
Chris
I always try to work backward.... whats a good condition trailer like that worth? $4K? (would be in my neighborhood) so 4K - 1K for fixes, another 1K looks (paint/rust etc)
In my neck of the woods a trailer like that would be listed on CL for at least 1200 perhaps as much as 1800-2K (because of the above math)
Ford 8340 (A53317)
Ford 8340 (A53317)
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
2022 Horizon (A55973)
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
AUCTION STARTS HERE @ 9AM (A60429)
AUCTION STARTS...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
