make-shift electrode oven
/ make-shift electrode oven #1
nsmithnd
Bismarck, ND
Ford 1700
Does 7018AC have the same moisture issues that plain old 7018 has?
Yesterday I used the last stick of a 1 pound box of 1/8" that I had picked up a couple of years ago to try out.
Once I got it going it stayed lit for me (running at 120 on the old Forney), then I opened a new 5 pound box which I had no problems starting.
Later on as I was digging through my messy work-bench looking for something, I came across a magnetic oil pan heater (which has burned me on more than one occasion). Knowing that the 5 pound box would soon become hard to light as well, I started wondering if the 300-400 (based on the specs I found on-line) degree magnetic heater stuck to a chunk of pipe might get hot enough to do the trick for those of us that shy away from 7018 and don't weld enough (or are too cheap) to buy an oven.
Any thoughts as to whether or not this might be worth experimenting with? (always looking for an excuse to fire up the welder and tinker with something)
-Neil
/ make-shift electrode oven #2
/ make-shift electrode oven #3
good question...not sure. I have a small portable oven i got 3-4 years ago for about $200 at my supply house. it gets very warm..not hot to the touch on the outside, but i cant handle the rods inside without gloves....verrrry hot.
The 3/4" of insulation does wonders to keep the heat in. I dont see how an exposed pipe can insulate it. You might have to place this setup inside another larger pipe and seal the ends. ... wait, homeland security might think your making bombs LOL
/ make-shift electrode oven #4
I bought an old toaster oven for $5.. worked like a charm. The rods I had needed to be baked, not maintained, so I had to remove the safety fuse to get up to 600+ degrees F for an hour.
I don't use 7018 any more, so I tossed it a few weeks ago.
Sean
/ make-shift electrode oven #5
I use an electric fry pan with lid. The extra long fry pans will hold 5 lbs of 14" rods placed corner-to-corner. The pans are cheap at WalMart or a yard sale.
Since welding is not done daily on the farm the rods are cooked on high for about 4 hours before a job is tackled. Seems to work fine.
/ make-shift electrode oven #7
I think a magnetic heater on a piece of pipe would work great for heating rods for a small job.:thumbsup: 7018AC also needs to be kept dry but like Shield Arc said, it doesn't need an oven unless it's either got wet or you're doing code work.
/ make-shift electrode oven #8
Old dorm reefer, guts removed, 60 watt bulb installed.
Keeps my welding rod dry and keeps other things I don't want to freeze warm in my unheated garage. Paint markers, flashlight, gasket goop, that sort of thing. Kept it about 60º during the little stretch of -20º weather we just had.
/ make-shift electrode oven #9
You better stock up on those incandescent bulbs. Ban took place Jan1 on manufacturering of them so what is in stock is what we have left to choose from. Those refrigerators with 100 watt bulbs keep them dry to some extent but not like a heating coil set per manufacturers standard of 300F for low hydrogen. Still likely good for home use though.
/ make-shift electrode oven #10
I stick weld so little these days I keep them in my closet inside the house. Less temp change and humidity there than in the shop.
/ make-shift electrode oven #11
Appliance bulbs last the longest. I use an old upright freezer, for about twenty years now.
/ make-shift electrode oven #12
So what am I suppose to use in my old fridge to keep my welding rods dry, once I cant get no more 60 watt incandescent bulbs? Those new bulbs don't give off as much heat.
/ make-shift electrode oven #13
Get a small halogen light. I had an old fridge for rods too. It had a metal freezer box. I used a light bulb under the metal but I think a magnetic heater stuck on the bottom would have worked great.
/ make-shift electrode oven #14
I think you can get little ceramic heaters that go into a standard socket. Search for reptile supplies.
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
2015 Volkswagen Golf SportWagen Sedan (A61574)
2015 Volkswagen...
Athens Harrow Scrapers (A64119)
Athens Harrow...
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
