Majic Paint On Motor
   / Majic Paint On Motor #1
mtnxtreme
I’m gonna repaint my Ford 2000 with Majic paint, I’ve had good luck with this paint, but wondering has anyone used it in the motor, can it withstand high temps, or do you have to use motor specific paint ?
I see a lot of guys here with freshly painted tractors, do you just spray everything even the motor with the same paint ?
   / Majic Paint On Motor #3
I would not use the (TSC) Majic paint on any tractor.
It is cheap junk!
Sherwin Williams sells quality implement paint!
Use hardener too!
   / Majic Paint On Motor #4
It is cheap junk!
Use hardener too!
For me, Majic has not worked out. My best bet is with factory OEM paint. Doesn't cost much more and is usually superb quality.
It's difficult to paint an engine unless you "detail" it by masking all the wires and protecting things from overspray. A good job looks great while a bad job means the guy should have just pressure washed it and left things alone.
So with the Sherwin Williams or OEM paint we can paint the motor too ? We’re gonna mask everything off
   / Majic Paint On Motor #6
It will burn off of the exhaust manifold and it won't stick on anything that has oil/grease/dirt on it but, WTH? Paint it anyway.
The most important part of a paint job is the prep work. How clean it is, how free of oil, grease, dirt, rust, imperfections, dents, etc.
The paint itself is relatively inexpensive. If you're gonna go through all the trouble of all the prep work, including masking and making sure you don't get overspray all over Mama's new car (you can get hurt doing that) then go ahead and buy some professional qualty paint and borrow somebody's spray gun (better yet, borrow the spray gun's owner). You can buy one but good ones aren't cheap. Do you need a good one?
Or if you wanna just slap some paint on there and call it a day, that's okay too. It's better than not doing anything at all.
Good luck and tell us how it works out. Pictures please :)
   / Majic Paint On Motor #7
You need heat paint, often called UHT--ultra high heat paint and even that will generally burn off.
"Username taken" in the prior post offers some good advice.
I can paint, I've got a cheap Devilibiss primer gun, and a $400 Sata I use for finish on cars, just wasn't sure if any of these paints were designed to be used with high temps also ?
   / Majic Paint On Motor #9
Unless it's specifically for exhaust manifolds (which is sometimes quite the process) it's gonna burn off. It's a PITD.
The last headers I cared about were Jet Hot coated. New.
That was many years ago and I stopped caring about such things, so it might be different today. But, to me, by the time you remove the header (manifold) get all the rust off, paint it or coat it, find gaskets and put it back on -- Only to have the paint/coating start coming off in spots and the manifold start leaking exhaust (hate that sound)........
Sounds to me like you know more about these things than I do anyway.
PICS!! :)
PICS!! :)
I always painted motors with heat paint, but never a tractor, figured it might be different because it's out in the open. I'm gonna pull all the tin, have it media blasted and shoot them separate.
2021 Ford F-150 XL (A50120)
2021 Ford F-150 XL...
FIRESTONE 20.8R42 REAR TIRES WITH WHEELS (WHEELS FITS GENESIS TG-T8000 TRACTORS) (A52748)
FIRESTONE 20.8R42...
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
2015 Dodge 5500 4X4 Bucket Truck (A52748)
2015 Dodge 5500...
2014 UTILITY 53X102 DRY VAN TRAILER (A52141)
2014 UTILITY...
Horst Quick Tach Bucket (A52349)
Horst Quick Tach...
