Maintenance on an 851 Powermaster
   / Maintenance on an 851 Powermaster #1
851 PM Ford
Cottageville, SC
Ford 851 Powermaster
851 powermaster.jpgBought an 851 Ford powermaster over the weekend, my first tractor. All seems well at present, needs new lift arms851 powermaster.jpg soon, need to buy a tarp until I build a shed, and Oil is black, so gonna change the oil this weekend when done with work. I would like to find a cheap maintenance manual, even if a PDF download. Does anyone have experience with this tractor. I am a newby and I want to keep the baby gently working for as long as possible.
I cleared my 11 acres, and was weighing hiring the grading and root raking out and then bush-hogging later vs. getting my own. Got this tractor, a new bush hog and a scrape blade for less than 3 grand. It seems sound, don't want to run it long with the black oil. Any mentors would be appreciated.
Thanks, my name is Trey
   / Maintenance on an 851 Powermaster #2
Look on e-bay, search "ford 851 Manual" I found a bunch. It's a close cousin to a NAA and other ford tractors of that age. For your arms look to places like Steiner tractor. Don't abuse or overload it, Keep the fluids changed, Keep your gas clean and treat it when the tractor will be sitting and tune it up occasionally (points and plugs) and it will last a very long time. Good choice for a first tractor. Oh yeah, wash and wax it occasionally.:) One more thing. If you plan to pull anything with a regular hitch (like that trailer) consider buying a proper drawbar (one that bolts the back of the tractor). The bar you can get that goes on the three point can be very dangerous.
Thanks for your reply sir! Gonna go ahead and order both arms and change the oil on Saturday. The 8 hour trip to get it and come back have stunted my spending until this thursday nights payday.
Any ideas where to find the oil drain plug? I've searched for a schematic and can find none. Don't want to acccidentally drain the wrong fluid by mistake!
I will go ahead and get that manual from Ebay like you recommended, 25 bucks for 6 different pdfs is reasonable I think. Thanks again and hope to hear back from ya.
   / Maintenance on an 851 Powermaster #4
Oil drain will be bottom of the engine oil pan. It should be fairly obvious. I don't know exactly on that tractor.
   / Maintenance on an 851 Powermaster #5
Welcome Trey!
That's a great machine...is it gas or diesel?
You can find the manual for either version on tractorclub.com's site. Just scroll down until you find the Ford 801 series (821, 841, 851, 861 all the same manual).
NTC Manual Library
Yeah OTF, I went out to my property at lunch time, a **** blind man could find that drain plug! Thanks!
It is a gas Gman. Thanks for the tip! I'll have to check that out! I puttered around at lunch for an hour, I got a 7 way scraper and tried it out. Too many roots, got 2 of my kid cousins coming saturday, gonna pick roots all day and see if that helps.
Hit a buried stump and caught a steering wheel in the gut, OOF! Oh well. Thanks for the help guys!
   / Maintenance on an 851 Powermaster #7
You should change the trans fluid,diff fluid and hyraulic fluid too. Three plugs under the tractor (smaller than the oil plug). Front one is transmission, middle one is hydraulics and rear one is differential. The seals between the sections often leak, so it's frequently best to just buy UTF and use it for all sections.
The hydraulic fluid in the middle section goes through steel pipes in the transmission. Water in the fluid rusts those pipes and the trans overflows. It's probably smart (but a messy job) to take off the manifold from the hydraulic pump to the transmission and clean the tubes with a gun brush and swabs to get the crud out. And they ALL have crud in them that wears out the hydraulic pump.
Also, the shift "plungers" wear. They are replaced externally and are pretty cheap. (40-50 bucks total) Replacement takes about 10-15 min.
Here's new and old.
[/URL][/img]
[/URL][/img]
The round part fits into a hollow on the shift rails. That is what holds the trans in gear. Once they wear, the internal parts wear and then the gears pop out more and more. Especially 3rd going down hill.
Thanks for the tip John Bud. How many gallons total of "utf" are we talking here? Is that UTF 134 that I've read about are there any filters involved? This tractor is 40 minutes from my house, I don't live on "the farm" yet. I know I quite literally put the cart before the horse (or house, or shed for that matter), but I just got tired of paying other people to do these tractor jobs..... If it runs now, you think I've got another 50 hours before I change all these fluids? I know the pto, clutch, and pto bearings were all changed within the last year, and I felt that all those fluids had to be replaced as they drained out when the was done, (I was told). (not a great mechanic YET, but motivated and neccessity is the mother of invention no?). I KNOW that black oil can't be good, so was gonna start with that....
   / Maintenance on an 851 Powermaster #9
Google found this. I haven't verified it with my manual. It's somewhere...
Capacities (by the book) are as follows:
Cooling System - 15 qts
Engine Oil (with filter change) - 5 qts (remember the air cleaner as SouNdguy said).
Tranny - 4 speed - 6 1/2 qts
Hydraulic Reservoir - 9 qts
Diffy - 11 1/2 qts
You undoubtedly have 50 hours or more :). I'm on a 500 hour / 3 year schedule for those fluids and 100 hours for engine oil. Typically, water infiltration is the biggest issue. Since you store the machine outdoors, you may want to find a way to cover up the exhaust pipe, shift lever, etc. I use a coffee can on the exh stack over the top of the flapper. On the 5 speed, there isn't a boot on the shift lever like a 4 speed, but you may still want to get a tarp on it.
   / Maintenance on an 851 Powermaster #10
I have an '58 Ford 861, maintenance is super easy, AND Napa has most of the parts you need!
I've upgraded to a 12 volt system, electronic ignition and a alternator.
Much easier to start.
I also took off the hydraulic top cover and had the local tractor shop redo all the seals and o rings, as well as plumb it for a rear remote.
Less than $200 for all that.
Note- the cover is thick cast iron, a two man lift!
Next is newer tires... $$$
Unused 2025 Pure Electric Cart (A51694)
Unused 2025 Pure...
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A53426)
2018 INTERNATIONAL...
5' Box Blade (A50123)
2016 FREIGHTLINER CASCADIA SLEEPER (A53426)
2016 FREIGHTLINER...
2017 Ford Transit Connect Cargo Van (A51692)
2017 Ford Transit...
