Maintenance light will not go out
/ Maintenance light will not go out #1
toy1
Goshen, CT.
kobota KX 080-3,R630, KX121-3, L48, L4630, bx23, cat257, M9000,(3) RTV1100,jd450h, ASV100 ,zd331,
Hello all I just got finished with the 200 hr service and tried to reset the maintenance light on my L4630GSTC with no success. I have reset it before on prior maintenance work. I have called the dealer and he had no explaination, anyone else have this problem?
/ Maintenance light will not go out #2
My recollection is that there is a tricky sequence that is described in the manual, which I'm sure you are following. I've used it and works for me. If you are using the proper sequence, perhaps there is a timing thing. Try running thru the sequence either faster or slower... maybe it'll work. Last idea... disconnect the battery and reconnect it.... sometimes computers need to be "reset". Hope you figure it out!
/ Maintenance light will not go out #3
Usually it is a bad ground somewhere, or perhaps a loose fuse....
I did attach a fused cable to the battery to get a 12 volts outlet to the back of tractor to run a top dresser, I did this sometime between 150 hrs and 200 hours I wonder how this may have impacted the issue?
/ Maintenance light will not go out #5
Check your manual for the location of all the electrical grounds, there should be 3 or 4 of them. Loosen them and rub them with sandpaper and then reattach. Also, remove and reinstall the fuses in the fusebox just in case one has come loose too.
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
UNUSED KUBOTA 48" PIN ON BUCKET (A64280)
UNUSED KUBOTA 48"...
UNUSED WOLVERINE SB66-66" ROCK BKT (A64281)
UNUSED WOLVERINE...
iDrive TDS-2010H...
2011 BMW 5 Series 528i Sedan (A61574)
2011 BMW 5 Series...
