1999 L3710 800 hr Service
   / 1999 L3710 800 hr Service
For just about double that cost, you could get a Grammer air suspension seat to fit your tractor complete with under the seat compressor. Most mount on the standard 4 holes and takes a standard 16 gauge wire to run 12 volts to the compressor. Comes with arm rests and a back rest. You won't believe how comfortable those Grammer air suspended seats are.
Thanks, but no thanks, I don't spend much time on it. I've put less than 500 hours on it since I bought it in 2003, less than 2 hrs. per month. When it snows, I need it, when the road washes out I need it. Other than that, it just sits these days.
The only reason I'm replacing the seat is that it soaks up water and is about to fall off the tractor :ROFLMAO:
   / 1999 L3710 800 hr Service #12
Get yourself a Talon online. What I did. Got mine for under 200 bucks delivered and it come with arm rests too and it's cordrura so rain don't effect it.
I have a grammer air ride in my cab tractor and I don't find it to be that comfortable actually. The Talon is much better comfort wise imo.
   / 1999 L3710 800 hr Service #13
probably the main reason why my hydraulic hoses last so long is, my units stay inside the barn when I'm not using them so no to little Ozone degradation and little paint fade either. Firm believer in storing expensive equipment INSIDE at all times when not in use. Mine won't fit in the garage anyway, too big and tall.
2015 Nissan Rogue SUV (A56859)
2015 Nissan Rogue...
New/Unused Quick Attach Pallet Forks (A57454)
New/Unused Quick...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2012 MACK CHU613...
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
SAKAI SV414D SMOOTH DRUM ROLLER (A52709)
SAKAI SV414D...
