maintenance crew
/ maintenance crew #1
mtsman
Pennsylvania
F16D, F22D
After a thundershow it was kind of misty and I thought these pics came out good. This is the maintenance crew or my 2 other boys. I plagerized "the boys" from from some other poster on here so I owe you a plagerization fee. /forums/images/graemlins/wink.gif
Even though I have the bigger one now I still like the f16D better for cutting our grass. It gets in smaller areas and goes around the seedlings real nice.
I need to do a search for UFO. Anyone know what the other 2 button on the UFO switch box do? I see some open quick connect fittings on wires down to around the lift arms and I believe these wires head up to the switches. One is a 3 position switch and the other is a 2 position.
/ maintenance crew
Here is another shot of the work ends. The log is on the blade just for ballast while I was using the loader on some wet soil/pea gravel mix. We had almost 8 inches of rain in July. I don't think I've ever seen the springs that high in July.
/ maintenance crew
UFO answer
OK. I found what I needed to know about the other 2 UFO switches using the search. Has anyone hooked a rear work light to one of those wires attached to the other 2 UFO switches?
/ maintenance crew #4
Re: UFO answer
Mtsman,
what did you find out about the UFO switches? I've got them but still dont fully understand what they do. thanks, bw
/ maintenance crew
Re: UFO answer
<font color="blue">( Mtsman,
what did you find out about the UFO switches? I've got them but still dont fully understand what they do. thanks, bw )</font>
BW,
I did a search for "UFO" and chose " all posts". There were at least 2 pages of links. I posted before saying I have an answer but I just went back and read a few links again and I do NOT have my answer as to what the 2 position and 3 postiion switch do. I found out what the 2nd lever by the rear lift lever does but not the switches. The dealer also said he does not know what operations the switches perform which initially bothered me considering the volume he sells.
I did not get a tiller with the 22 since I have one with the 16 but in hindsight I think I shoud have.
2017 Ford Escape 4WD SUV (A61574)
2017 Ford Escape...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
(2) UNUSED 16.9-24 TIRES ONLY (A64280)
(2) UNUSED 16.9-24...
UNUSED IRLMC DELUXE MASSAGE CHAIR (A64281)
UNUSED IRLMC...
UNUSED WOLVERINE HYD SICKLE BAR MOWER (A64281)
UNUSED WOLVERINE...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
