Main Bearing
/ Main Bearing #1
dgougeJD430
John Deere 430
I have a 1959 John Deere 430W i am restoring. i have machined the block and head, but finding main bearing has become a problem. i cannot go any further with the engine rebuild until I found them or have them made. Does anyone have these main bearing, or can anyone give advise on where to have them made or purchased. i have looked all over the internet.
/ Main Bearing #2
I don't know where to find 430W parts, but thought I'd answer just o that I can follow this thread and if we find a good source of old parts it will help everyone. Gotta be some. There are a lot of old of JDs being restored.
I see in the business magazines that there are even some outfits doing complete rebuilds on the bigger JD ag tractors from the '70s. Apparently they were so innately rebuildable that a worn 4030/4050 100 hp tractor can be refurbished at a competitive price to new machines.
Ours 1958 John Deere 530 is the same vintage as yours, and was stock for 30 years and then we added a JD wide front & FEL some 40 years ago....Both upgrades simply bolted onto existing frame lugs. It's a marvelous machine. I'm currently beginning to look for parts to finish a long overdue clutch & brake job on it, but other than that it is fine.
In fact, it hasn't changed noticibly in the last 40 years, and back then any parts I wanted were as close as the local dealer. In 1990 when I went to buy a tach/speedo, tune up and carb kits & some gaskets plus that bizarre automatic fuel tap - the dealer had everything in stock! Perhaps it helped that the 530 shared many parts with the B series. Those parts have to be out there somewhere. Does the 430 share with other models? With the M?
In summary, I don't know where to get old parts because the 530 hasn't needed much. But hopefully we can both find a source.
Good Hunting,
rScotty
/ Main Bearing #4
Standard sizes are still available from Deere. Undersizes are not.
/ Main Bearing #5
Check this guy out: John Deere 430 Parts - Yesterday's Tractors
Main Bearing Set - Complete main bearing set for 2 cylinder models 420, 430, 440. Main Bearing Set, 1 required per engine. Available in Standard, .020, .030. Specify required size in comments section of order form when ordering. (Part No: MS-319P)
$121.44​
willy
32" Mini Sifting Bucket  (A62679)
32" Mini Sifting...
66in. Skid Steer Bucket (A65640)
66in. Skid Steer...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
