Mahindra MPOW85 has no power, bought New:
   / Mahindra MPOW85 has no power, bought New: #1
SHORE
Worthington, MN
Mahindra MPOW85
Tractor has 81 hours on it, I've had it for 7 months. It starts out real slow in any gear. It has been like this from the start. Dealer said there was a pinched fuel line, supposedly fixed that..did not improve performance. Many other problems, won't go into them here. Any solutions?
   / Mahindra MPOW85 has no power, bought New: #2
Kubota M? Kidding... Mostly.
   / Mahindra MPOW85 has no power, bought New: #3
The dealer should put it on a dyno and get some objective numbers.
   / Mahindra MPOW85 has no power, bought New: #4
Make sure it is hitting on all cyls. The way I do it is to just touch the exhaust at each cyl. close to the head. They all should be HOT and about the same.
   / Mahindra MPOW85 has no power, bought New: #5
sounds like a fuel delivery problem, have you changed the fuel filter?
   / Mahindra MPOW85 has no power, bought New: #6
Sounds like it needs to go to the dealer. 7 months and 81 hours, there should be no questions asked on any and all problems it has.
   / Mahindra MPOW85 has no power, bought New: #7
Can be any number of things. Fuel delivery, loss of compression, anything. Best thing to do is get a hold of your dealer and go from there. "No power" is not something that can (usually) be diagnosed without someone looking at it.
   / Mahindra MPOW85 has no power, bought New: #9
Sounds like it's in limp mode. Has the dealer check to see if any codes are recorded?
Tractor has been at the dealer numerous times. I had it put on Dyno at local JD dealer(twice). PTO hp is 61-64. When I have complained to Mahindra Customer Service and to dealer about the hp, the Customer service said that advertised HP is Motor HP, Not PTO horsepower.
If i am pushing snow and the rpm's are at 1000 it will not speed up when you give it throttle, it will just back off instead. Must have it over 1000-1200 rpms to have any power at all to push snow. Temperature outside is at 30-40 degrees when using it. it is not a fuel issue.
The dealer did a complete oil and fuel change at 50 hours, and it has not improved the power at all.
John Deere 9450 Combine (A50514)
John Deere 9450...
2019 HINO 268 26FT BOX TRUCK (A52141)
2019 HINO 268 26FT...
2012 BOBCAT E80 EXCAVATOR (A51242)
2012 BOBCAT E80...
Wolverine Mini Skid Grapple Bucket (A50514)
Wolverine Mini...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
