Mahindra MPOW85 has no power, bought New:
   / Mahindra MPOW85 has no power, bought New: #31
Its interesting that the OP hasn't posted since November.
   / Mahindra MPOW85 has no power, bought New: #33
Maybe they finally fixed the thing or maybe he found out it was something he was doing or maybe the dealer done away with him:eek:.
Or maybe he took your advice and quit making payments and it ruined his credit and he lost his house and is living under a bridge somewhere waiting for his lemon law mediation hearing, without wifi so he can't post....
Ha! Keep your sense of humor Dick, just yanking your chain!
I do hope he had it checked out and they got the HP up to spec. Then if he runs the rpm up near normal, I think he will be happy with the tractor. They can be a little doggy under load from an idle, mostly due to EPA constraints. The old 7520 (predecessor to the mPower85 and 8560) was a hot rod, but it did throw out some smoke doing so.
   / Mahindra MPOW85 has no power, bought New: #34
Yep between me, Mahindra and that dealer, his life is ruined forever. What a team. It's almost as if the gubberment was involved somehow. Only they know how to screw with people like that but they don't need no hep.
   / Mahindra MPOW85 has no power, bought New: #35
He probably pulled on that throttle out of frustration and shot that workhorse in the air :laughing:
   / Mahindra MPOW85 has no power, bought New: #36
Tractor has been at the dealer numerous times. I had it put on Dyno at local JD dealer(twice). PTO hp is 61-64. When I have complained to Mahindra Customer Service and to dealer about the hp, the Customer service said that advertised HP is Motor HP, Not PTO horsepower.
If i am pushing snow and the rpm's are at 1000 it will not speed up when you give it throttle, it will just back off instead. Must have it over 1000-1200 rpms to have any power at all to push snow. Temperature outside is at 30-40 degrees when using it. it is not a fuel issue.
The dealer did a complete oil and fuel change at 50 hours, and it has not improved the power at all.
Did you ever get your 85 lack of umpf figured out. I have one with 875 hrs and it has been similar since 500 hrs. No real 83 hp power. Thanks for your time. Rik
   / Mahindra MPOW85 has no power, bought New: #37
Crank that motor up- listen to the turbo, it has to spin fast to make HP.
My 8560 sweet spot is @1750 rpm, subsoiled shoved as deep as it will go can stop forward motion but wheels keep turning until shear bolt breaks. If shear bolt don’t break, it will dig 4 holes till it bottoms out.
BTDT in a soggy Duck Hole.
   / Mahindra MPOW85 has no power, bought New: #38
Last two day getting a ch.en.lt after warm up then goes limp, barely 1500 rpm. No throttle response but idles perfect. Very cold here now but no issues last season. Will try to pull some codes later but not sure if my car scanner will work and if it does won't know what the codes mean.hahaha
   / Mahindra MPOW85 has no power, bought New: #39
Sounds like you need a good dealer that can troubleshoot it.
Could be some sort of electrical glitch.
Sometimes it takes a lot of effort and money to repair equipment.
I have spent 3k on BadBoy Buggy,
Almost 1k on a Mule and
10k on a 06 Duramax.
14k on equipment repairs that would cost 100k to replace.
All in the last 2 years.
   / Mahindra MPOW85 has no power, bought New: #40
Nearest dealer is 2.5 hrs away. I'll figure it out or the pink bunny will have to sit and watch me use a 33 year old German air cooled Deutz 4wd get the work done around this ranch. Best engines ever made IMHO. Next to no electronics to fiddle with. Just needs a cab with heat and AC like my 85P.
KUBOTA M7060 TRACTOR (A51243)
KUBOTA M7060...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
2018 HINO 258 S/A SERVICE TRUCK (A51243)
2018 HINO 258 S/A...
2011 Chevrolet Malibu Sedan (A50324)
2011 Chevrolet...
2020 Nissan Altima Sedan (A50324)
2020 Nissan Altima...
