Mahindra Max 28 electrical
   / Mahindra Max 28 electrical #21
drajj5....just got a call yesterday that tractor was done, they put a whole new wire harness in it and a fuel solenoid in it,...the sealed connector that the solenoid plugs into was full of water, that shorted the solenoid out....it sounds to me from talking to the sales guy, that this is a known issue with a few tractors. they have had the tractor for 3 weeks now...went there to make arrangements to get it back yesterday and looked at my baby and the hood looked like it had been thru a war...they had it off for the repairs and it must have been kicked all around the shop and something dropped on it. they offered to send it out to a bump shop to get straighten and painted, i told them i want a new hood! got a message first thing this morning said they are replacing my hood, the dealer has been great through all of this...just a series of unfortunate issues, i dont know how long for a hood now,,,but a need my tractor back!!
Well I am glad that they got it sorted out. I am shocked that they replaced the whole harness though!!! amazed that they pulled the hood at all, I was careful to place the two side panels in a safe place while I fooled with mine. Super glad that your dealer has made things right and without question replaced what was damaged. Thanks for letting us know what they did to repair your- electrical dilemma.
   / Mahindra Max 28 electrical #23
good info in this thread. I had an electrical issue with mine at the ~10 hour mark I think, the wiring for the seat switch got caught up in the mechanism that allows the seat to spin around for backhoe-ing, wasn't ziptied at the factory (or something). not a big deal, and had it not been brand new I would have fixed it myself.. Dealer came out, investigated and verified what I'd said, and ended up replacing the whole seat (I guess the switch wasn't available individually?).
anyone else had issues with their batteries making a mess of the tray/lower front end?
   / Mahindra Max 28 electrical #24
got tractor back...running great, just waiting for replacement hood:thumbsup:
   / Mahindra Max 28 electrical #25
I did find out what the cylinder shaped thing was - it was a ETR solenoid. Used to shut engine off when you turn ignition switch off.. For those who were curious.
There was no power to the "load Relay".....Well my meter read 12vdc but when a test light was used it would not light up. Bazaar; that voltage was present, however when I applied a load it voltage would drop off.
FYI:
Not sure about this case, but often that will happen when you're measuring the voltage at a "cut' negative wire, or where there is an open switch in the negative wire.
That is imagine a simple 12VDC circuit with a light bulb (or whatever the load is), where the negative (ground) return wire is cut or switched ( & floating). If you measure the voltage of the cut /floating return wire, it will read 12vdc, because there is no current flowing, thus no voltage drop across the load (light), thus your measuring the 12VDC of the source in a wire you'd expect to be 0 volts.
Now if you complete the circuit with a light tester, the 12VDC is split across the (resistance of the) load and the resistance of the bulb in the tester. If they are of equal resistance, it would be 6v across the load, and 6 volts across tester, which may not be enough voltage to operate either one.
He is right..... there can be many variables to the equation. His explanation is well written, and can explain lost/corroded grounds. I can only troubleshoot by comparing it to a, " State Highway Map"-envisioning that bundle of wires as roads on a map leading to each destination. 'Corny I know', but it is how I get the problem fixed. That is why I need to use schematics' when I make repairs. Guess others use my technique as well to simplify any electrical issue!:thumbsup:
   / Mahindra Max 28 electrical #27
On another note, but similar, this happens commonly on a dirty battery cable. Lights often work, at least the dash light. But as soon as you turn the key to start - everything goes dark and no cranking, despite having good voltage when the battery is tested. People then call and want to order a switch or a starter. We insist that they clean all connections, which annoys people at first. They later call and...what do you know, it runs good now. And sometimes that bad connection is not at the battery end of the cable. You have to check both ends.
We had a fuel shutoff solenoid fail last week on a Mitsu/Mahindra. Appears they get their ground through the threads where it screws into the FIP. These threads had paint on them. I think that made a poor ground and caused the solenoid to fail. Seen this 3-4 times now, out of hundreds sold. It's like a batch got painted with the threads exposed. Seems to happen within the first 20 hours if it happens at all. We have never seen one fail beyond that. The symptom is that it will start and then immediately die when you let go of the key and it returns to "run" from "start". I expect a cut wire at a crimp may be a similar scenario.
   / Mahindra Max 28 electrical #28
Jim, did you ever find out what the problem with you tractor was? I had the same problem today with my Max 22. Was spreading fertilizer, stopped to refuel and that was it. Would not run. engine would start but when the key was released it would die. Dealer is closed today or I would call to see if he could send me a schematic. Seems almost certainly to be an electrical problem, but without a schematic I have no idea where to start.
I think I found my problem. Using the info on this website I went to the fuel solenoid and pulled the connector. Like others I found water inside...not sure how it got there, (my tractor is always in the garage when not being used) and blew it out with compressed air. Tried to start but same symptoms. knowing how solenoids can be finicky I provided a little mechanical agitation with a block of wood and the handle of a screwdriver, tried starting again and success! WooHoo. Thanks for the info folks.
   / Mahindra Max 28 electrical #29
Were you using a pto operated spreader? Did you disengage the lever before trying to start? If you didn't, there is your problem.
Good to see you found this issue- and fixed it!! awesomefx, I think that he may have had multiple issues as they replaced both the solenoid and wiring harness on his max 28.
Glad to see a post on this site helped you with yours..
2014 KALMAR 4X2 YARD DOG (A50854)
2014 KALMAR 4X2...
2023 GTC 39 END DUMP TRAILER (A50854)
2023 GTC 39 END...
2018 Terex RL4 4000W Towable Light Tower (A49461)
2018 Terex RL4...
2013 RAM 5500 (INOPERABLE) (A50854)
2013 RAM 5500...
Drill Bit attachment (A50322)
Drill Bit...
MAHINDRA 2816 TRACTOR (A51243)
MAHINDRA 2816...
