Mahindra Max 22 Won't turn over
   / Mahindra Max 22 Won't turn over #31
Title of this post made me laugh. We moved from PA to Texas and are still hearing things that confuse me and make me scratch my head.
Neighbor says the old tractor won't crank.
Here I find out he meant won't start LOL.
I asked.. is the starter working? He said yes.
So I said so it is cranking but it's not starting?
He made a funny look.
   / Mahindra Max 22 Won't turn over #32
OK, my problem with a new KIOTI 25CK. Engine would not start, the delar said to bypass the seat safety switch because that is a problem with this tractor! OK, no safety seat switch. My John Deer lawn tractor has a seat safety switch, that works. Also this tractor a 5 amp fuse that goes to the soloniod comes loose at times and the tractor will click but not start.
   / Mahindra Max 22 Won't turn over #33
I had the same thing happen on my old max26. I got tired or trying to figure it out and just wired in a push button to the starter. Id turn my ignition on, wait for glow plugs, then push the button to start it.
   / Mahindra Max 22 Won't turn over #34
Same on my Mahindra 1526 HST. I had or replace that positive terminal and paint the battery tray.
After that venture I replaced the battery with a larger AGM battery. No problems since then.
   / Mahindra Max 22 Won't turn over #35
seems everyone eventually has the issue, amperage is simply too high for the connector
these have worked flawless for years for me, 0 corrosion after installing, I put them literally on everything.
https://amzn.to/3MrxCVK
Even applying grease to the base of the posts is also a preventative.
There is also a battery terminal spray available that basically accomplishes the same thing that I think is shown in the kit you posted..
   / Mahindra Max 22 Won't turn over #36
yep put on the rings and spray everything exposed and the issue is gone.
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A57024)
2002 Chevrolet...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2022 John Deere 9RX 640 Track Tractor (A53485)
2022 John Deere...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2015 Chevrolet 1500 Silverado Pickup Truck (A55852)
2015 Chevrolet...
