Mahindra Max 22 Won't turn over
   / Mahindra Max 22 Won't turn over #31
Title of this post made me laugh. We moved from PA to Texas and are still hearing things that confuse me and make me scratch my head.
Neighbor says the old tractor won't crank.
Here I find out he meant won't start LOL.
I asked.. is the starter working? He said yes.
So I said so it is cranking but it's not starting?
He made a funny look.
   / Mahindra Max 22 Won't turn over #32
OK, my problem with a new KIOTI 25CK. Engine would not start, the delar said to bypass the seat safety switch because that is a problem with this tractor! OK, no safety seat switch. My John Deer lawn tractor has a seat safety switch, that works. Also this tractor a 5 amp fuse that goes to the soloniod comes loose at times and the tractor will click but not start.
   / Mahindra Max 22 Won't turn over #33
I had the same thing happen on my old max26. I got tired or trying to figure it out and just wired in a push button to the starter. Id turn my ignition on, wait for glow plugs, then push the button to start it.
   / Mahindra Max 22 Won't turn over #34
Same on my Mahindra 1526 HST. I had or replace that positive terminal and paint the battery tray.
After that venture I replaced the battery with a larger AGM battery. No problems since then.
   / Mahindra Max 22 Won't turn over #35
seems everyone eventually has the issue, amperage is simply too high for the connector
these have worked flawless for years for me, 0 corrosion after installing, I put them literally on everything.
https://amzn.to/3MrxCVK
Even applying grease to the base of the posts is also a preventative.
There is also a battery terminal spray available that basically accomplishes the same thing that I think is shown in the kit you posted..
   / Mahindra Max 22 Won't turn over #36
yep put on the rings and spray everything exposed and the issue is gone.
2012 Dodge Charger Sedan (A55853)
2012 Dodge Charger...
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
JOHN DEERE 323D SKID STEER (A52707)
JOHN DEERE 323D...
2009 Ford E-450 Super Duty Ambulance (A55852)
2009 Ford E-450...
IVEY'S 7' AERATOR/PLUGGER (A57192)
IVEY'S 7'...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A57024)
1992 Talbert 70...
