Mahindra loader Valve Repair
   / Mahindra loader Valve Repair #1
Dave48
Mahindra 26xl Max
Mahindra 26xl Max loader Valve Repair can't find the right place to find the parts to fix mine not a hydraulic mechanic so all help will be appreciated
   / Mahindra loader Valve Repair #2
I may not be much if any help. If it’s the loader valve it remotely controlled by a cable, make sure it’s working. If it’s the hydraulic valve if you can get a clean table and take it apart you will see the problem. Talk to us a little more after you try a little bit
   / Mahindra loader Valve Repair #3
I doubt it's a cable type joystick, but somehow I suspect the joystick IS what you're having trouble with. Right/wrong?
Explain the problem a little, someone will help you out.
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2013 Vermeer BC900XL Towable Brush Chipper (A52377)
2013 Vermeer...
Lockwood 480 Pecan Harvester (A55301)
Lockwood 480 Pecan...
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2000 Ford F-150...
