Mahindra loader Valve Repair
   / Mahindra loader Valve Repair #1
Dave48
Mahindra 26xl Max
Mahindra 26xl Max loader Valve Repair can't find the right place to find the parts to fix mine not a hydraulic mechanic so all help will be appreciated
   / Mahindra loader Valve Repair #2
I may not be much if any help. If it’s the loader valve it remotely controlled by a cable, make sure it’s working. If it’s the hydraulic valve if you can get a clean table and take it apart you will see the problem. Talk to us a little more after you try a little bit
   / Mahindra loader Valve Repair #3
I doubt it's a cable type joystick, but somehow I suspect the joystick IS what you're having trouble with. Right/wrong?
Explain the problem a little, someone will help you out.
Utility Trailer (A52377)
Utility Trailer...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A55218)
2017 Yale GLC050VX...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
