mahindra HD rotary cutter comparison
/ mahindra HD rotary cutter comparison #1
araz33
I am trying to decide on a new rotary cutter. I have narrowed it down to the 8' HD Mahindra and the 8' AG Modern Predator.
I have a Massey 431 and would like to use a pull behind type. I'm using a 6' cutter now but I have always wanted to widen the footprint. My limitation is the 46HP PTO.
In comparing cutters I found the Predator requires 45HP and the Mahindra 60-70 HP per their literature. Gearboxes compare 100 center/90 HP outboard (Mahindra) to 150 center/95 outboard Modern.n
weights compare 1225 Mahindra to 2370 Predator
The Mahindra does not have blade overlap and the Modern has a 3" overlap.
Well as far as HP required does anybody have and opinion as to why the differences.
Can I depend on the requirements listed or do you think they factor in some cushion.
/ mahindra HD rotary cutter comparison #2
I don't want to dampen your spirits on a 8 ft cutter, however, I have never found a 8 ft rotary cutter that would cut without leaving a streak in the middle (especially worse when cutting higher). I personally would go with a 7 ft or a light duty 10 ft. Ken Sweet
/ mahindra HD rotary cutter comparison #3
I have an 8 foot Mahindra HD with dual spindles. It's a 3 pt not tow behind. It mows great, very nice quality and seems pretty beefy. It does not leave a streak of grass in the middle at all. I'm using it behind a Mahindra 2555. 55hp, 48 at pto. It has no problems at all through thick grass
/ mahindra HD rotary cutter comparison #4
As long as you cut low, you will never notice the streaking problem. It shows up when we cut higher as in clipping pastures 10-12 inches. Ken Sweet
