Mahindra emax 22 warning light, need help
   / Mahindra emax 22 warning light, need help #1
Big Chief
stratford,CT
mahindra emax22 loader, backhoe
Watch the video
If i sit in the seat and start tractor as normal no flashing lights.period
If i sit in the seat with brake on, key on (not running) and get out for something and get back in the seat (which closes the seat switch) the warning light flashes and then goes away once running.
No running or performance issues at all
Seems to me to be a warning that the safety start cycle was interupted.
No one seems to have ever had this problem.
Any thoughts
Shared album - Dr Wayne Ritchie - Google Photos
[video]https://photos.app.goo.gl/qwqDS9j3NFydwcjm6[/video]
Bueller? Anyone?
   / Mahindra emax 22 warning light, need help #3
I've had the mil light flash during start up. Never really worried much about it though. Always goes out after start up.
Ok thanks anyone else seeing this on their machines?
   / Mahindra emax 22 warning light, need help #5
I have never seen this on mine but will give it a try today like you said above and let you know what happens.
   / Mahindra emax 22 warning light, need help #6
Must be a Sasquatch alert to turn the Sasquatch lights on :D
Jokes aside. Looks like it's throwing some sort of code. Do you have any manuals of the tractor?
Big foots are all around this neck of the woods, lol
Manual shows nothing.
Tech at a Mahindra dealer over the phone never heard of the flashing light series I have.
I have fixed every piece of equipment I have ever owned and really don’t want to Take my computer with a loader and backhoe on it to the dealer.
No trailer, distance and down time...
Thanks for the replies
Anyone else?
   / Mahindra emax 22 warning light, need help #8
Well I tried the same on my e-max and did not get the flashing light.
Ok thanks guys
I had to take it to my local dealer today. I will keep you updated on what happens
Update
I spoke to the dealer today after connected to the computer the code 34 showed as indicated by the flashing light. 126 times it was recorded.
It is a fail to start code of some sort. ECU was reflashed which upgraded the glow plug cycle time and temp settings.
Cleared all codes and it happened again:mad:
After a few hrs of tracing wires they found a harness that was worn through causing the problem.
I am glad they found it and confirmed the problem.:thumbsup: it is in the same area as the hose that was rubbing on the frame.
I will update you guys again once I pick it up.
ITEM LOCATION (A53084)
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52748)
2018 John Deere...
2009 Freightliner Columbia 120 Winch Truck, VIN # 1FUBA5CK39DAM2731 (A51572)
2009 Freightliner...
2022 New Holland Powerstar 90 Tractor with Loader (A51573)
2022 New Holland...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52748)
2018 Dodge Ram...
