Mahindra emax 22 warning light, need help
   / Mahindra emax 22 warning light, need help
OK guys I got the tractor back yesterday. There was a piece of harness in the seat and tail light harness underneath the middle of the hydro pedals that was worn through. It wasn稚 enough to cause of short but enough to give feedback to the ECU and make the check engine light to flash a code 34.
Once that was repaired and fixed and upgraded to prevent it from happening again the computer was also re-flashed with the new updated glow plug timing and temperature settings.
The glow plug upgrade would allow you to use a block heater. However with the new Settings it痴 not necessary.
I use Bethany tractor in Bethany Connecticut also known as Johnson auto who advertises here on this forum. It痴 a small family run dealership and they have excellent service and a real good guys.
Electrical gremlins are very time consuming and then they could致e taken me to the cleaners and they were very fair and reasonable when I went to pick up the tractor. Jeff and Scott are brothers who own and operate the dealership
I hope this helps
   / Mahindra emax 22 warning light, need help #12
I hope this helps
Hey did u happen to need a frame replacement on your tractor?? I ended up buying a pretty nice used machine from them and would just like more history as im told mine was a buyback and that it was repaired, but there is a few small kinks im looking to figure out without paying too much in diag fees and repairs.
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
Misc Gas Equipment (A56469)
Misc Gas Equipment...
CFG Industrial QK20R (A56469)
CFG Industrial...
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
2003 Big Tex 10PI...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
