firefighterfox
8560 will not start with key switch. I can jumper the battery wire on the starter to the small solenoid wire and it will crank. And if the key is in the on position it will start and run. All fuses check with voltage on both sides. I have also put a jumper on the hot ignition switch wire to the cranking wire on the switch and still it will not crank.
Does the cranking wire from the ignition switch go to something else before it goes to the starter solenoid. I have no schematic.
Thanks for any help.
