Loader Mahindra 7010
/ Mahindra 7010 #1
M135
I have a Mahindra 7010 tractor with an ML 170 loader. Hydraulics of the bucket will not hold when rolled out as when the operator would use to backdrag or smooth a pile of soil. It simply rolls the bucket back like there is no resistance and/or the hydraulics is not holding the bucket in place. Is this problem in the joy stick control? Does anyone have experience with this issue? Thanks.
/ Mahindra 7010 #2
check your fluid levels before you worry too much.
Then connect/reconnect any and all hydro quick connects.
/ Mahindra 7010 #3
Will loader lift front end of tractor off ground? Make sure joystick is not getting pushed all the way forward to the float position.
/ Mahindra 7010 #4
Unless something has really changed, I don't thing that the float function of the lift circuit has anything to do with the curl circuit of the bucket. :eek:
/ Mahindra 7010
The fluid levels are fine. I can reconnect the hydro quick connects but all other functions are working properly. I have not tried to raise the tractor with the loader but can give that a try. Other ideas?
/ Mahindra 7010 #6
You can or you did the reconnects? remember you have different hoses for lift and tilt functions. if you haven't disconnected/reconnected, you should try it.
/ Mahindra 7010
No, I have not tried that yet. I will try that and let you know. Thanks.
/ Mahindra 7010 #8
Might be worth a try. Try to curl the bucket like you want it. Return joystick to neutral and then do it again. Doing that on mine will cause it to lift the tractor up so I can back drag
Brett
/ Mahindra 7010 #10
Other than that your fluid could be bypassing internally and need to be rebuilt.. they arnt showing signs of leaking are they?
/ Mahindra 7010 #11
It sounds like an issue with cavitation. Are you dumping the bucket and then finding this happens? If you roll the bucket ALL the way out and then cycle it back to the angle you want does it still do it?
/ Mahindra 7010
Sorry to be late getting back with you. The disconnect/reconnect solved the issue.
thanks for your help!
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
2019 Caterpillar 239D3 Compact Track Loader Skid Steer (A61572)
2019 Caterpillar...
2006 Toyota Sierra CE Van (A61574)
2006 Toyota Sierra...
Adams 5 T Fertilizer Spreader (A63688)
Adams 5 T...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
Hurricane Power X3 Walk-Behind Debris Blower (A61572)
Hurricane Power X3...
